Question about Lenovo 3000 N200 Notebook
Lenovo 3000 N200 battery not charging.
It went into shutdown as the battery was low. I plugged in to charge the battery and the battery is not charging. The battery light flashes red for about a monute then stops. I have tried removing the battery and putting it in again but not working.Could u help.
I just had the same problem. My battery had discharged to less than zero and would not start even though the power plug was in. I tried everything... but what fixed it for me was to remove the power plug, remove the battery, plug in the power cord and start the machine. Once the machine was already booted, I put the battery in and it started charging. Dont know if that will fix your problem, but it fixed mine.
Posted on Oct 22, 2009
    Problem Solver:
  • 6 Answers
Buy a new one from ebay
its fucked
Posted on Sep 05, 2009
    Scholar:
  • 92 Answers
Http://www.laptoprepair101.com/ could be your power port if you know how to use and volt meter on your laptop it should tell you how many amps that you should have coming through the port .if there is a lower reading. check out the site above for laptop repair info .if it is not the port you will need a new battery ,laptop batterys most often last about 2 years they make extanded life batterys but none are proven to last mor that 2 years . good luck let me know what happens
Posted on Sep 08, 2009
2 Suggested Answers
  • 39 Answers
SOURCE: Lenovo 3000 N200 battery wont charge
no it might not be a battorey problem it could be a software problem,
Posted on Sep 13, 2008
HI, i Have lenovo 0769-A63 laptop i have problem in my battery, when i put AC then my laptop is start,battery shows 83%(pluged in,Not charging). when i remove the AC System is cloosed is just like Cpu, its...
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 12, 2011 | Lenovo 3000 N200 Notebook
Lenovo 3000 N200 0769wont charge, i brought a new battery and charger which both work the problem is the power doesnt seem to be going through to the battery to recharge it what could be causing this
Was the adapter you bought directly from Lenovo? I just know that dell builds in a chip to detect the adapter, if not original it will not charge the battery. I do not know if it's the same issue.
Feb 16, 2011 | Computers & Internet
I have a new battery of my lenovo 3000 n200 yesterday i have charged it for 18 hours before use ... then used the computer on battery power ... when it reached 34% I have plugged the charger I got the...
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Sep 01, 2010 | Lenovo 3000 N200 Notebook
My lenovo 3000 n 200 will not start :/ the only thing i can see is a lamp showing " Y " . when i put the charger to the computer the lamp who showing that the computer charging is not lightning. when i...
First tip is disconnect the battery and Adapter, hold down the power button for 30 sec. and the insert your battery and adapter and try starting. Let me know is this works or I can suggest something else.
Feb 06, 2010 | Lenovo 3000 N200 Notebook
Lenovo 3000 N200 Power Problem
It seems like the issue is with your Laptop Battery.
Please try to check the same battery with some other laptop & see if that works, other wise you have to go for a Battery Replacement.
Hope this resoultion will help you to get the battrey issue resolved for you.
Cheers!!!!
Vivek
Dec 25, 2009 | Lenovo 3000 N200 PC Notebook
Lenovo 3000 N200 laptop not starting up, power light on
Keep pressed the power button of your laptop for about 30 seconds, the machine will power down.
--The above step may not be required as already so many days passed by.
Then plug it into the power adapter.
Switch the laptop on.
Boot in "safe mode" (F8 during boot).
This will fix any driver or some operating system issue during previous failed boot process.
Once it boots completely, do a normal shutdown and reboot your laptop in standard mode (no more F8 this time).
Now your laptop will be ready to use.
Sep 30, 2009 | Lenovo 3000 N200 Notebook
Laptop fan spin for 2 second and display not show
You must veryfi the CPU and try without battery or try it without charger with a already charged battery! This must work!
Sep 13, 2009 | Lenovo 3000 N200 Notebook
Low sound in lenovo 3000 N200
My Lenovo 3000 N200 not recognize an WD Scorpio Blue 160GB sata
Jun 05, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Sep 11, 2008 | Lenovo Computers & Internet
Lenovo 3000 N200 Notebook Logo
5,463 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
