Question about Compaq ProLiant 3000/5500 Redundant (306558B21) Fan Assembly
Compaq proliant 5500 server P2 dual xeon processors. Will not power on. green lights on both powers supplies are on - green lights on Mother board and LCD on front are on but absolutely nothing happens when pushing power button
    Sergeant:
    Novelist:
  • 190 Answers
I am wondering if you had been doing some work to this when this problem started. Did you take the wires off for the power switch? I have noticed that sometimes if you pull the wires off of the motherboard and put them back on and you put the connector on backwards (assuming that its a 2 wire cable for the front panel) it may not work. Also, if you have a screwdriver handy which Im sure you do, take the plug off of the motherboard and jump the 2 pins that start the system. If it makes the system work then change the switch. If that does not work then try checking the power supplies. Just because the light is no does not mean that the power supply is working correctly. Will the system work with just one power supply hooked up. If so try one at a time. I have also had luck with re-seating the processor and the system then booted correctly. Try reseating the ram. Bad drives, cards and cables can make the system not start. Unplug everything that you can and if it starts, plug one thing in at a time and see if you can eliminate the bad part. Hope this helps...
Posted on Sep 07, 2009
CAN I INSTALL XEON 5540 WITH LGA1366 MOTHERBOAR
NOT ON JUST ANY MOTHERBOARD, that's a quad core, the mother board has to have quad core clocking. You need a server board. All the desktop boards are only dual core clocking.
Feb 20, 2014 | IBM Xeon E5540 FCLGA1366 2.53G 8MB 45NM...
What version of Linux runs on DL580 G4?
Minimum Supported Red Hat Updates •Red Hat Enterprise Linux 5 Update 1 •Red Hat Enterprise Linux 4 Update 5 6-Core/4-Core Intel Xeon Processor 7400 Series •Red Hat Enterprise Linux 5.22 •Red Hat Enterprise Linux 4.7 Minimum Supported Novell Service Packs•SUSE LINUX Enterprise Server 10 SP1•SUSE LINUX Enterprise Server 9 SP31 6-Core/4-Core Intel Xeon Processor 7400 Series •SUSE LINUX Enterprise Server 10 SP23 •SUSE LINUX Enterprise Server 9 SP44
Nov 28, 2012 | HP Compaq ProLiant DL580 G4 (430811001)...
Server is not powering on
Switch PSU between bays Use spare PSU
If server is still not working PSU backplane needs to be replaced. IS spare PSU sovles the issue, then it was a faulty PSU
Feb 26, 2011 | HP Compaq ProLiant ML350 G5 Server
The server comes on for a mili second and recycles power does the same repeaditly, it was working fine all of a sudden poof it turns off no warning, i turned the swich off, and then back on it came on,...
The PSU , if it sees outputs dead or overloaded they all do that.
test the PSU unplugged with the power on pin jumpered
if voltages all pass tests and it stays on, it can be ok.
then find who on the MOBO end is shorted.
by removing things , like all HDD< and DVD or all things
but CPU.
even pull ram. all things in electronics can in fact short.
Sep 04, 2017 | Compaq ProLiant 5500 Server
ProLiant DL160 G6 Server, Part Number 593352-B21, Serial Number USE029N5Z2. The system fails to power on. The power supply has the LED light green. The start button does not turn amber. Do not...
ProLiant ML150 G6 and DL160 G6 (HP Smart Array B110i SATA RAID) does not support more than 4GB memory, (2GBX2 modules) or more added, it works fine with single 2GB module. Boot OS with single module and upgrade system Rompack to the latest version then upgrade B110i controller driver to 6.8.0.32. Shut down the server, add additional modules. It will work fine.
Aug 04, 2010 | HP ProLiant DL160 G6 Server - 1 x Xeon...
Compaq proliant 5500 server wont power up
In my experience when a server/computer does absolutely nothing when the power button is pressed it is a dead processor. That may not be the case in your situation. It could be as simple as a defective power switch. Is the switch a soft touch or does it push in and click? Does the switch feel normal when pushed? One of the power supplies could also be bad. Do you have any good power supplies to test in the server? Were there any power outages recently that could have caused damage to the PSU? I would start with checking the switch. You could hook up a circuit tester and see if the switch completes the circuit when depressed. Also take a look inside the server and look for any loose connections on the mainboard. It is possible the wire for the power switch has come loose.
Sep 05, 2009 | Compaq ProLiant 3000/5500 Redundant...
Compaq proliant dl350 processor
As standard it has 1x Xeon single core 3.2GHz with a 2nd free CPU Socket
Jan 20, 2009 | HP Compaq Proliant DL350 (345101-001)...
What is it worth?
Honestly, it depends on the make (g1, g2, g3) and configuration (how many processors, amount of memory, how many disks, type of RAID card, redundant power and if it woks) I remember these machines were pretty bulletproof. Find out the config for each, then you can make a fair comparison using ebay.
Apr 20, 2008 | HP Compaq ProLiant ML530 Server
Compaq ProLiant 3000/5500 Redundant (306558B21) Fan Assembly Logo
151 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
