Question about UTStarcom PCS1400 Cellular Phone
Cant get phone to charge, and it keeps turningon, and then going off... and wont show that its charging when charger is plugged in
My Lg is not keeping charge, and I bought a new Battery and it still wont charge or keep charge. Please Advise.
A charging problem could be due to a bad battery, corrosion on the battery contacts (you can clean them with rubbing alcohol) a bad charger or the charger plug on the phone. I would try replacing the charger and checking the connects.
Jan 13, 2016 | LG Cell Phones
Once i plug in my charger its wont charge!
Turn it off, & keep it off for a while. It's happened to me as well. Turn it back on & plug the charger in.
Dec 16, 2011 | Sanyo SCP-2700 Cell Phone
My samsung rant wont charge. it charged yesterday but today after plugging it into the charger the Samsung name lights up and then it says "low battery please charge" but it wont charge, i did drop it in...
Phone not charging.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 10, 2010 | Cell Phones
My phone wont charge.... i have bought a new battery, charged it for 24 hours, and it still wont charge. even when it does charge it wont keep the charge for more than a day. why wont it charge. plzzzz...
It could be the charger itself that has the issue. If you have another charger try that. If you have done this and it still won't hold a charge I would contact your service provider they will try to trouble shoot issue but more than likely will get you to send phone in through warranty if your still eligible. If not eligible for warranty and don't have insurance ask about upgrade options. Hope this helped.
Apr 13, 2010 | Samsung Blackjack SGH-I607 Smartphone
Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
May 23, 2009 | Compaq Presario 700 470024-192 Notebook
Wont connect
replace battery
Mar 14, 2009 | Lands Phones
NOKIA 6600 wont charge and turn on
hey,
how about check your charger .. maybe there is a problem with your charger... try another nokia charger
Cheers
Aug 28, 2008 | Nokia 6600
Just unlocked Motorola V3 but cant get it to work with o2 sim
in order for it to work rite its going to need a fulll charge. i will plug mine in to the wall or outo and keep pluging and unpluging it not from the phone but the wall or cigaret lighter untill it charges it. try removeing the battery
Jan 09, 2008 | Motorola Mobility RAZR V3
UTStarcom PCS1400 Cellular Phone Logo
104 people viewed this question
Top UTStarcom Cell Phones Experts
iphone service
buzzcola
Level 1 Expert
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
