Loaded new cartridge and got error signal 30 stating that the cartridge is not there. It appears in properly. Troubleshooting intstructions suggest I view switch that hangs down from front left of cover. I don't see that. It appears to close properly. The printer is old, but has always worked great. Issue started with a paper jam and while correcting I decided to replace the cartridge. Help thanks
Cartridge Error .... help!? I've read all the other replies and it's not helped!
Just make sure you are using a genuine Lexmark cartridge and not some remanufactured, refilled or clone cartridges. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
You may also contact Lexmark Technical Support Center for additional assistance.
Jan 14, 2012 | Lexmark X4650 InkJet Printer
HP officejet 6110 all-in-one. 4 years old - is suddenly giving a problem. The message "Error: Left cartridge incorrect" keeps appearing. The left cartridge is the correct one (HP 57) and is...
i would suggest you to remove the left cartridge once and clean its golden metal contacts with soft cloth and reinstall it again.
this can give some difference
Sep 17, 2008 | Office Equipment & Supplies
Black Cartriddge missing
Try taking out both cartridges from your printer. Re-brick your printer by pulling out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. When the printer turns on, re-insert your color cartridge then close the cover. If no error appears, re-insert your black cartridge. If error still appears, then it could be a faulty cartridge. It would be best to replace it with a new cartridge, preferably a genuine one. Lexmark products work best when original supplies are used.
Dec 02, 2011 | Lexmark X4270 All-In-One InkJet Printer
Have closed cover properly. cover vup sign still there.
Try to follow the steps below to identify and fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on and comes back with the error on the display screen, please contact Lexmark Technical Support Center for additional assistance. If no error appears, reinsert one cartridge first.
  6. Close the printer cover and check for any errors.
  8. Replace whichever cartridge is causing the error to appear with a new cartridge.
  9. If no error appears, try to print again to verify that the problem is fixed.
Oct 12, 2011 | Lexmark X3470 All-In-One InkJet Printer
Cyan color cartridge "appear to
http://h10032.www1.hp.com/ctg/Manual/c00485555.pdf
Apr 22, 2011 | HP Photosmart 3210 All-In-One InkJet...
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
Error #1203
The error indicates either a communication failure between the cartridges and the printer or by a short in one of the cartridges. Here's an article on Troubleshooting a 1203 Error Message on the Lexmark X5400 Series. Just click on this link: http://bit.ly/aDUAjM. Follow the instructions on the page. However, if the problem continues, I strongly suggest you contact Lexmark technical support for assistance. Thanks.
Aug 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Print Cartridge problem
OK, it sounds like the printer needs to be reset or turned off and on again, including unpluging it from the wall for 30 seconds or so.
If the new tri color print cartridge is not at fault, it's the circuitry in the printer.
Follow the link below for hp.com's troubleshooting procedure:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=1128297
Jul 13, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Cartridge Error
There might be a part inside the printer that is broken. The carriage might have been damage also. You've already done the hard reset and also replace the cartridges, then the only solution for this is to replace the printer since there is a broken part on it.
Jiffy Epe
HP Technical Support Representative
Aug 11, 2008 | HP Officejet 5610 All-In-One InkJet...
26 people viewed this question
jasbo
jasbo
