Question about Humminbird Fishfinder 525 406260 1
Humminbird 525 fishfinder, battery is fine, unit runs ok in simulator mode, it powers up ok in normal mode, displays for 2 seconds, then the screen goes white, you can just see the reading, but only just, it is like it just fades away, how do i fix this?
  • 76 Answers
Hi!
Sorry to say it sounds like you will need to replace the screen assembly which is about a $70 repair or so.
This is best left to a qualified Humminbird technician who has access to parts and support.
here are the numbers:
Where to ship your items:
(if you live in the U.S.)
Humminbird
Attn: Service Dept.
678 Humminbird Lane
Eufaula, AL 36027 Who to call:
Toll-free: 1-800-633-1468
Monday - Friday
8:00am - 4:30pm CST
Authorized Service Centers - Canada Bay Distributors
119 Progress Ct.
P O Box 70
North Bay, Ontario, Canada P1B 8G8
Tel: (705) 476-6010
Email: info@bwmarineproducts.com
Mike's Reel Repair
#108-31060 Peardonville Rd
Abbotsford, BC V2T 6K5
Tel: (604)855-1119
Email: mikesreelrepair@gmail.com
www.mikesreelrepair.com
PTG Electronics Ltd.
3092 Portage Ave
Winnipeg, MB R3K 0Y2
Tel: (204)831-0862
Fax: (204-888-6207
Email: Ptg_ltd@mts.net
Posted on Sep 26, 2009
Is it any battery inside the Humminbird 525 fishfinder unit ?
No, the only battery operated ones are the Piranha portables. Having said that, there might be a small CMOS battery purely to hold saved information like tracks and waypoints.
May 10, 2015 | Humminbird 525 Fishfinder
I have a Humminbird fishfinder 525. It goes directly in simulation mode and says: No svinger connected... What could be the problem?
If the transducer is disconnected, it will automatically go into Demo Mode.
If you do have the transducer connected, but the boat isn't in the water, the unit knows there is no water and after a few seconds, switches to Demo mode.
Not sure what a 'svinger' is, but if you need more help, just ask. I can also edit the message and change 'svinger' to something else.
I have had both the Humminbird 798 and also the 1198HD. They are great pieces of kit on the water. The 525 is entry level.
My unit allways stay in simulation mode how to start it working
Start-Up Options Menu
Press the MENU key when the Title screen is displayed to
access the Start-Up Options menu.
Use the UP or DOWN 4-WAY Cursor keys to position the
cursor, then the RIGHT Cursor key to select one of the
following choices. If you wait too long, the system will
default to whichever menu mode happens to be highlighted:
• Normal
• Simulator
• System Status
Feb 27, 2014 | Humminbird 595c GPS Receiver
I need schematic of fishfinder 525 Humminbird. My equipment doesn't switch on.
no power going to unit or you have a bad key pad and its not going to come on
Sep 09, 2013 | Humminbird Fishfinder 525 406260 1
Stays in the display mode only, tried turning it off and on , unplugging and going through all of the options
Contact our customer service group and they should be able to help you out. The Humminbird Service number is 800-633-1468.
Feb 11, 2011 | Humminbird 525 Fishfinder
I have Humminbird 525 fish finder. I have power to the mount but no display on the screen.
If you have someone that has the same or simular unit just slide there control head to the base just to make sure you have enough voltage and current to power the unit. If the other unit powers up then there is a problem with the control head. Then you will need to call customer service to get it resolved.
Jan 24, 2011 | Humminbird 525 Fishfinder
I want to see the schematic diagram of humminbird fish finder transducer, my fishfinder won't operate. if i plug another unit of transducer, the my fishfinder operates normally.
Hi Greg and Ernesto:
Re-stating the obvious, your transducer is not working but you know that the sounder is.
I would start by checking to see if your transducer works on a different sounder. That's just a double check to confirm that it really is not working.
Then I'd try to isolate the problem:
- Plug (couold be corroded or damaged)
- wire (could be broken)
- Transducer (could be defective)
Since these are sealed units, I'd be checking with the supplier to try to find a replacement. Hopefully they are not too expensive, and time spent fishing is better than trying to maybe save a few dollars, especially if you're taking out charters.
Best of luck.
Sep 01, 2010 | Humminbird Fishfinder 525 406260 1
Turns off
The first thing you need to check is if you have sufficient power going to the fishfinder. Take a multimeter and measure the dc voltage going to the display when the unit is off and also on. If this is below 12 vdc this is your problem. You will need to check for loose connections and possibly replace your battery.
If the voltage is good then the problem lies within the display. Unfortunately, you would have to contact Humminbird directly to return the display for repair or purchase a new fishfinder.
Jun 29, 2010 | Humminbird 161 Gps Fish Finder Combo
Gain failure
If you are 'testing' the unit by holding the right button and pressing power, the pmax units really don’t work with the internal test. What you are seeing in the test is what th humminbird factory computer test used to test it. That is really not intended to be used outside of the plant. If it works fine in normal mode then I would say that the unit is fine.
Best of luck!
Mike
Jun 28, 2009 | Humminbird Piranhamax 220 Fishfinder
Humminbird Fishfinder 525 406260 1 Logo
482 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
