Question about Kenmore 24902 Top Load Washer
WONT AGITATE OR SPIN
I have a kenmore 92282100 cc 2498105 it doesn't want to agitate OR spin, it'll fill up, and if i hold down the lid switch during either agitate or spin modes, i can hear the motor, but no movement.It will drain during the spin cycle as well.
  • 62 Answers
Check the belt that spins the tub, you will find it at the bottom of the machine, check if its intact.
plz do not forget to vote if i solved your problem
Posted on Sep 05, 2009
  • 4 Answers
If it's not the belt/motor/transmission, this sounds like the exact thing that was happening to mine. Google something to the effect of "how to remove front panel of xxxxxxx washing machine". You will either need a new clutch clip or re-bend the old.
Fix
New part
Posted on Jan 27, 2013
I have a Kenmore washer model 110.26832690 that will not spin. It will fill up, agitate, but on spin cycle it will only drain. Does this sound like a bad lid switch or a bad drive adapter? From what I've...
if it agitates correctly,then its likely your lid safety switch, agitate and spin cycles are reversed by the motor during the cycles of agitate and spin,some units are wired to not operate on either agitate or spin,but some will operate on agitate with the lid open,but not on spin,open control panel and bypass the lid switch and this will tell you before you tear out the direct drive pump,motor and get to the d.d. coupler at the transmission
Mar 20, 2011 | Kenmore Washing Machines
Washer wont agitate
if it wont agitate,then it's either your motor coupling,transmission,or capacitor
Feb 11, 2010 | Kenmore Washing Machines
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 110.25842400 fills with water and doesn't do anything else. Can't get it to spin, agitate or drain.
check to make sure your lid switch is clicking. Some Kenmore clothes washers will not spin or agitate if the lid switch is not working. Hope that helps.
XCEL Energy Repairman
Apr 27, 2009 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore 70 series
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
May 15, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 wont agitate or spin
The Lid switch has gone bad. The new part is available from sears and costs $25.00.
Apr 14, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Kenmore 24902 Top Load Washer Logo
255 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
