Question about Kenmore Dryers
Kenmore gas dryer does not run model #110.97591220
  • 234 Answers
The first thing I would check is to see if 120v is coming into the unit. In my 8 years in the appliance repair business, I've seen this problem many times. Flip your breaker back and forth.
Good luck :)
Posted on Sep 15, 2009
3 Suggested Answers
marka19
  • 1430 Answers
SOURCE: I have a kenmore gas dryer, model 110-9644190. It
For a free video on diagnosing this go to www.appliancehelponline.com/servicemanual.html
could be thermal fuse,thermostat,dryer coils,ignitor
Posted on Feb 26, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Posted on Apr 14, 2010
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Feb 26, 2010 | Kenmore 63942 Dryer
My gas dryer runs but no heat.
Most gas dryers use a surface-type ignitor, a ceramic element with traces that glow to ignite the gas and yours has failed. BTW, it's helpful to give model numbers so we don't have to guess.
Aug 27, 2009 | Kenmore Dryers
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Will not heat
glow bar igniter ... - thermal fuse ( not all models ) ... - coil on the gas valve ... - gas valve ... - thermostats ... - motor heat switch ... - timer ... - selector switch ... - sensor ... All these will cause this problem.
Mar 22, 2009 | Kenmore 74672 Gas Dryer
Kenmore Model 110.76912691 gas dryer that heats intermitently
Replace the solenoids on the gas valve. These are often intermittent befor total failure. Hope this helps!
Feb 26, 2009 | Kenmore 63942 Dryer
Kenmore gas dryer model#73022 no heat when running
The first thing is to look at your tech manual and do a continuity test on the thermistor.
Oct 23, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 72602100 gas dryer runs but no heat
gas dryers would have an igniter to start the flame. check it first to see if its still ok. be carefull in handling them, they are very fragile. check also for availability of gas. could have a closed valve.
Jan 30, 2008 | Kenmore 63942 Dryer
Dryers Logo
107 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
