Question about Hoover HW130M Front Load Washer / Dryer
Drum spins for a bit then stops. Strange grinding noise and flashing.
The Drum of my Hoover washer/dryer spins for a bit then stops. There seems to be a grinding noise and when I took the back off and switched the drying mode on I noticed a strange flashing light from the motor, as though someone was welding from it the noise was obviously attributed to this as well. What do you think the problem is and how can it be fixed?
The brushes are worn out and need replacing
Posted on Oct 18, 2010
    Sergeant:
  • 351 Answers
It may need new carbon brushes in the motor.
Posted on Mar 04, 2008
My Frigidaire Gallery front loading dryer seems to be out of balance. It has become louder and makes a rhythmic grinding noise as it spins. Sometimes it starts with grinding noise that stops after a...
YOUR DRYER DEFINITELY HAS A BEARING RUNOUT PROBLEM (THATS THE GRINDING NOISE YOU HEAR - THE DRUM RUNNING ON THE SIDE OF THE CABINET ) . IT WOULD ALSO GRAB CLOTHES AS YOU SUGGEST . COST TOO MUCH TO FIX = GO AND SHOUT YOURSELF A NEW ONE IF U CAN .
Jul 26, 2011 | Dryers
Drum loose so very noisy on spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 29, 2010 | Hoover Nextra HNWL 3136 Front Load Washer...
The washeers drum sounds a bit nosy I think smething might be stuck inside the inner drum. How do I get to check the inner drum?
the inside of the drum makes a clicking sound, and I located the noise at the back of the drum and the noise seem's to be in the central part where the bearings is located.
Jun 29, 2010 | Hoover Nextra HNWL 3166 Front Load Washer...
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
Dryer makes a sound as if there's a marble loose in some rotating part. It doesn't seem to be coming from the drum, because when I disconnect the band from the motor and hand rotated the drum at speed...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ghhgfhf
Mar 21, 2010 | Kenmore Elite HE3 Steam 8676 Dryer
Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Nov 09, 2009 | Washing Machines
I HAVE DRYER GE MOD #DWSR488EB2WW SER#ZG743601A ***HAVE GRINDING NOISE. RELPACED THE BEARING IN THE BACK. BELT SEEMS OK. PUT BACK TOGETHER NOISE CONTINUED. THE NOISE HAS A SLIGHT GRIND/SCRAPE IN ONLY PART...
The most likely cause is the front drum supports. There are 3 or 4 teflon strips (about a half inch wide and 2 inches long) on the top of the front panel that the dryer drum glides on. When these wear down, the drum can scrape on the plastic that holds them or on the metal frame around the door frame. Another possibility is if the drum touches the dryer exhaust vent pipe, most often only if the dryer is vented out the bottom of the dryer and the vent pipe has shifted up just a bit, allowing it to contact a spot on the drum with each revolution.
Oct 02, 2008 | Dryers
Hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
Apr 09, 2007 | Hoover H120M Front Load Washer / Dryer
Hoover HW130M Front Load Washer / Dryer Logo
288 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
