Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis F51 code - already replaced RPS. Now what?
F51 code. We replaced RPS and still getting code. Now what to do or replace?
  • 15,935 Answers
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
I had a problem with washing kenmore oasis he 110.27062600 it came on sd, f51 codes when it reaches to spin. clothes didn't dry .
Hello, welcome to FixYa.
The scenario you describe is usually associated with a item stuck under the tub or a loose stator or a faulty "RPS" device or connection at the "RPS"...but I don't know if you checked that yet or if you know how, thus the error F51.
As I mentioned the F51 is usually associated with the rotor and stator/RPS assembly and quiet often it is initiated due to a loose rotor or bad RPS...I'd start by checking the bolt.
There is a repair tip regarding this from sears which suggest checking the wires to the RPS and then the rotor, while insuring the center bolt is really tight via applying some "lock tight".
I actually see a lot of these and most times it's a loose rotor bolt. Here's an exert from my files directly from sears...(I'm privy to them from being a Sears tech.)
You may want to check the rotor, I've seen the center bolt become extremely loose, thus causing the F51 error, this where and what to look for shown below...
...but either way let me know how you make out with the repairs and good luck.
Regards,
Macmarkus :)
Oct 18, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Leaking and F51 error code on my Kemore Elite Oasis Washer
Jun 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does f51 code on a kenmore oasis mean
Dec 02, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis HE is flashing a code
sound like the rps kit is required and is time comsuming will have to remove the back and console includes harness and new rps sensor and inset for sensor if not sure if you can perform it would be better to call service tech....must remove from the bottom of the motor location(main drive d/c motor)
Aug 19, 2009 | Kenmore Washing Machines
F51 code
Jul 17, 2009 | Kenmore Oasis HE 27082 Top Load Washer
What does a code f51 stand for on a kenmore oasis elite washer
F-51 ERROR CODE IS DEALING WITH THE SPIN CYCLE. THE CONTROL DOES NOT DETECT IT SPINNING.THE RPS SENSOR ON THE BOTTOM OF THE UNIT NEEDS TO BE TAKEN OFF AND PUT BACK ON ABOUT 10 TIMES. SOUNDS WEIRD BUT USUALLY FIXES IT. THEY DO HAVE A KIT ALSO FOR THE RPS TO BE REPLACED. UNPLUGGING FOR A FEW HOURS IS A TEMP FIX.
Jul 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
342 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
