Question about Sony Cyber-shot DSC-W80 Digital Camera
LCD screen problems on sonycybershot 8.1, 10xzoom
The screen is black but I can see all information pictures (battery, flash icon, etc) When I take a shot, it comes black, but I can view all older pictures. Any other ideas what could help..?
Mine has the same problem. I have slapped the bottom of the camera on my open palm a couple of time while it was on and the picture came back on!
Hope yours is as easy of a fix!
Posted on Sep 09, 2009
What's your problem? Nikon Coolpix S220 - My screen is black and takes black pictures. I can still look at old pictures that are saved to the device and see how much battery power etc, but it will
i can recommend read very well you owner manual specially the troubleshooting section. The images in the LCD monitor will darken in strong sunlight or bright light. This is a normall occurrence the devices containing CCDS, and doesnot contitute a malfunctions.
If you are using too much the flash+zoom, the batteries quicly will drain. maintian another set of batteries for replace, or better buy recharges batteries.
God bless you
Jul 31, 2012 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
Jul 31, 2012 | Canon Cameras
Hi, When the camera is turned on, the LCD diaplay screen is blank (dark) and just displays various information icons for batterly level, megapixels, quality, flash-on, etc. When I try to take pictures, the...
The display being blank can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.since you are able to seen the ICONS the LCD is good , Now if the picture taken are seen well the CCD is also OK and the fault seems to be a digital logic gate failure as there is no switching of the circuit .
This might require a probe and it might be a relative issue in the motherboard circuit or the processsor. Remove battery , press down all buttons to drain off voltage and see if the camera resets.
Thank You for using fixya
Sep 27, 2011 | Vivitar ViviCam 4345 Digital Camera
The view screen is black and you can't see what you're taking the pic. Battery is ok
If camera shows Menu item or any on-screen display in LCD but no live view to take picture then it can be either aperture problem or defective ccd imager.
And if you do not see any display icon in LCD then of course LCD section is bad or LCD back light is Off for some reason. Try to see faint image in LCD if it is totally blank by pointing good amount of light with flash light or some thing.
Oct 16, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
Black lcd screen on Ixus 70 shows icons but will not take picture
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
SonyCyberShot DSC W80
If u r unable to see live picture on LCD screen in camera mode, it means CCD Imager of camera isn't working. Contact nearest Sony service shop for proper solution because it requires CCD Imager replacement.
Jun 07, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
LCD Display Blank
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
Feb 12, 2008 | Cameras
Sony Cyber-shot  DSC-W80 Digital Camera Logo
126 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
