Question about McCulloch Garden
I have a McCulloch Bearcat. It sat all summer. I
I have a McCulloch Bearcat. It sat all summer. I finally got it started after cleaning and changing the plug. Lots of blue smoke until it warmed up. Saw idles fine but I activate the trigger to start cutting it stops and won't start for 15 minutes.
    President:
  • 2,220 Answers
Did you remove the old fuel?
Did you refuel it with a fresh oil/gas mix? Mixed to the oil suppliers recommended ratio.
The fuel that sat all summer probably contains ethanol. Ethanol draws moisture, moisture and the oil suspended in the fuel don't mix. The old fuel can be used in a 4 cycle engine. Try refueling with a fresh mix if that doesn't work we need to investigate further.
Lou
Posted on Sep 05, 2009
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Will not start
Hi, Richard if your bike has been idle for months or years and does not want to start you will have to deal with a few remedies:
1. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
2. Remove your air cleaner and clean and re-oil per Mfg. specifications.
3. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
4. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
5. Replace spark plug with a new one and check for spark.
Good luck and have a nice day.
Nov 12, 2015 | GAS Motorcycles
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
Wontstartfilledtankwithpetrol
has it been running this year or are you just trying to run it after it sat all Summer?
Nov 16, 2013 | McCulloch 26cc Gas Blower Mcb3208
Gbv 325 wont start cleaned carb ,changed fuel ,changed spark plug but still wont start ,cant get spark
Your local service center may be able to assist.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Nov 03, 2013 | McCulloch GBV325 25cc Blow Vac
Yamaha 1200XL PWC won't start
hi there could be corrosion on the switch gear and kill switch check and clean as well as the wires going tostarter soliniod,corrosion on these electrical connections are always a problem cheers pete
Jun 11, 2013 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
My generator will not start
I bet the spark plug has water on it's gap. Take it out to clean and dry. I bet it will start then. Robert
May 11, 2012 | McCulloch 6.5 HP 3500W GENERATOR
I have a mcculloch chain saw. It tough starting, and when its does start is has very little power. I cleaned the carb out and still no change. Any ideas
Start by removing the fuel filter in the tank and replacing, remove the top cover and clean the air filter, if there is a spark arrestor in the muffler remove and clean the gauze. Now try again.
Apr 12, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
McCulloch 3200 won't run
sorry but really does sound as its only ran for 15 secs on the choke cleaner , we usually change the fuel filter ( thats inside the tank , use a hooked piece of stiff wire to pull it up ) , you will likely need to do a full strip and clean of the carb and fit a new diaphragm the small needle valve may well be stuck into its seat , also watch for the fuel line being perished , and very important , make sure its full of of chain lube oil and pumping correctly ( do this before you even fit the chain and bar )and the chain is tensioned correctly and the clutch and chainbrake operates properly
Nov 18, 2009 | Dryers
Garden Logo
123 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
