I have had this system for 6 years without a problem , all conections are good all of a sudden its not getting power as if an internal fuse blew how do I get power back ?
    Genius:
  • 1,144 Answers
Amps do not have internal fuses..does it have a remote turn on wire.and did u hook it up.
Posted on Sep 06, 2009
No power. Will not turn on
It may have tripped the internal breaker, and or the house circuit breaker. Go tot the house fuse box and check that first.
Mar 05, 2014 | Whirlpool Gold GU2275XTVy Dishwasher
Ignition fuse keep blowing in my 2003 cavalier
u have a dead short on main live wire check for overheated wires
Jul 10, 2012 | 2003 Chevrolet Cavalier
Cerwin vega avs sub8. no power. changed blown fuse and still nothing. no power light indicator. unless led light bulb blew which i believe to be unlikely it has no power. any ideas
I got the same problem, my sub was working perfectly and suddenly one day it did't turned on, so I think it is the protection from the internal transformer, it needs to be changed but I don't know the model, if someone else knows I would appreciate the info because it is a really good subwoofer for the size...
Jan 07, 2011 | Cerwin Vega AVS-5.1 System
My Kenmore HE5 dryer will not run without blowing an internal fuse. The repairman replaced the fuse, and it blew again. The dryer heats up but will not turn it's heating element off until the fuse blows....
Has any one checked the exhaust vent,other than a bad thermostat the number one cause for the thermal fuse to open is a clogged or restricted exhaust vent flow, the entire vent system needs to be checked ( not just the hose from the unit to the wall) for proper air flow. Turn the unit on TIMED ,AIR DRY (NO HEAT) and go outside to the exhaust vent and check the air flow,if there is any question as to weather the air flow is sufishent get someone out to clean the exhaust vent ,it always a good idea to clean out every few years regardless to help prevent build up of lint witch could cause a fire......Hope this Helps Good Luck
Dec 14, 2010 | Kenmore HE5 Electric Dryer
Shortage problem
So stop feeding it fuses and get it fixed. Internet isn't a good medium for hands-on repair.
Jun 06, 2010 | Philips HTS3544/37 Theater System
Kenmore elite 13852 will not show any lights. looks like no power but checked breakers in basement and everything looks good. Is this a bad door switch or is there a bad internal fuse? Thanks for any help!
INTERNAL FUSE,
but most of them dont have a fuse and it is the controll panel...
check with volt detector that you get power to the control panel if you do ..then its the panel if you dont , its the conection to your macine. good luck
Jan 25, 2010 | Kenmore 13859 / 13854 / 13852 Dishwasher
Our Panasonic CT-27HL15 set is only 4 years old and suddenly decided not to turn on. When you press the power button, it turns on for a second then makes a noise inside and shuts off. Any ideas is it worth...
I have one of those that is the same age and the 6.3 amp fuse was blown out. I replaced it with a 6 amp fuse (i could not find 6.3 nearby) and got a few more weeks use until the fuse blew out again. someone suggested i get a slow blow fuse next time.
Jun 20, 2009 | Panasonic CT-27HL15 27" TV
No power to tv
Replaced internal fuse. Need to remove back.Fuse type T3.15 A. This blew again.
Mar 28, 2008 | Bush 5693D 24" TV
Amp keeps blowing fuse
I have this same problem. You have blown the internal amp. I have had 2 of these do the same thing. There is nothing you can do but report it to infinity and try to get the unit replaced.
Dec 21, 2006 | Infinity BASSLINK Car Subwoofer
41 people viewed this question
 Grubhead
Grubhead
