Question about RTO Genova Water Hammer Muffler Plumbing Universal Pipes
I hammered a nail in wall an it wasent right so i took it out an water came out so i av put it back an its just dribbleing now what shall i do
  • 138 Answers
You better call a plumber
Posted on Sep 05, 2009
    President:
  • 1,015 Answers
You probably punctured a water line(probably plastic). You will have to shut off the water to the house and cut open the drywall to examine the damage. Leaving the nail in the hole will not solve the problem. You may have water leaking into the wall now.
Who is at fault, carpet fitter hammers nail into water pipe while gluing viynal down in bathroom
the person here is the plumber who put in that pipe
the worker is not to know that the pipe is not correctly positioned to avoid nails for the floor
talk with a lawyer as to what can be done
Jan 26, 2018 | Computers & Internet
Tip
Sheet rock on nine foot walls made easier
if you find yourself hanging nine foot walls with fiftyfour inch rock and the walls are
wooden framing, most have two boards running horizontal along the top. tap five
or six drywall nails along the top of the sheet were they will catch that top plate
and forget the screw gun save your back . use both hands get the sheet in place,
stay in tight with the sheet draw your hammer from your belt and tap in the prestarted nails.Three nails is enough to hold it if they are driven properly. But get
some screws in it asap. seems to save on my back hope it helps yours. Also works
well with two people as well.
on May 17, 2015 | PrimeSource Gypsum Board To Wood Stud...
ET200 won't shoot nails. The light works but it doesn't shoot. The chamber is clear of jammed nails HELP!
I had this problem too, and finally figured out what was wrong. If you have cleared a jam and have put the nail gun back together, then all you get is a 'thunk' when you try to drive a brad, you have put it back together wrong, as I did. Take the two screws out and pull out all four pieces -- three plates and one skinny 'T' shaped piece. Look inside the unit and you'll see a pointed piece, which is the hammer that drives the brad in. This next step is key: put the first plate back in (the one that is flat on both sides) making sure that it slides in UNDER the hammer. The hammer fits loosely in its housing, so it may help to turn the nailer upside down so that the hammer falls down, giving you the room you need to get the plate in--again, so that it's UNDER the hammer when you turn the nailer back over. Once you have done this part, simply slide the second piece in (the one with the fluted strip down the middle), slide it in fluted side up, then the 'T' piece (with the 'T' in first) then the last piece with the wider groove that contains the 'T' piece. Replace screws and you're back in business! This information may be in the instructions, but I have long ago thrown those away.
Oct 26, 2012 | Arrow ET200 Electric Brad Nail Gun
Does anyone have a diagram for the ET200 nail gun? I took it apart and can't put it back together.
I could not find one on the net. I would go to the Arrow web site and use the "contact us" link to send them an email requesting a diagram.
http://www.arrowfastener.com/
Mar 05, 2012 | Arrow ET200 Electric Brad Nail Gun
I took my arrow ET200 nail master apart to remove jammed nails. I need a diagram on how to put it back together
Susan Sylvia is exactly right. I just fixed my tool with her information. I would add to be very careful not to disturb the 2 small springs(associated with the trigger and safety mechanisms) and take note of how they are positioned. Also, the screws seem to strip unusually easily so be gentle when removing and replacing them.
Jan 24, 2012 | Arrow ET200 Electric Brad Nail Gun
Need to replace tub in old travel trailer. any help for removing old one, installing new one and supporting under floor if rotted??
First turn off water then remove the wall board ,or paneling at least 12 in above tub lip .,Remove more if you can.The more room you have the easer it is to slide the new tub into place. Now you should be able to reach the tubs drains unsrcew or cut them out When you have the drains disconnected .pull any nails or screws from around the tub. Look at the path you have to take to get the tub out ,you'll probably have to remove the toilet tubspout or maybe even the lavitory.when your path is clear put a flat bar between a stud and the inside edge of the tub pry the tub up and out. You way have to move from one stud to another.When its off the wall on the inside edge see if you can pick the back end of the tub up.This should make it easier.Remove all the bad flooring .You will need some lumber now replace the floor joist or scab onto them (you will need 3 or 4 ft of good joist on eather end to scab onto.If the edges of the new floor board dont land on a floor joist simply nail aboard onto the side of the joist it needs to meet on level with the other joist.Where the front of the tub sits cut a hole out about 10x12 in center of hole14and1/2in for standard tub and off the wall in front of the tub 12 in.This will give you room for the tub shoe(thats the part the tub basket screws into) Sit tub on flat level surface and measure from the ground up to the inside edge of tub .Nail a 2x4 on the inside wall about 4 ft long off the floor as high as the edge of the tub.Take your time and get this right if you dont you will have to pull the tub back up after you've set it in place..If you have room you can put the waste and over flow on the tub follow the instructions on the package use pipe compound on threds and plumbers putty on the basket lip.If your not going to be able glue the trap after the tub is inSet the center of drain 14 1/2 in off inside wall and 1 1/2 off front wall .put tub into place front in first drop down the back and slide tub ont the board you nailed up earlier level it up dont add pitch the tub has pitch built into it takes screws or roofing nail securing tub to studs hook up the drain P.S.dont nail or screw through the tub instead nail or screw just above the top liof the lip fill the tub completly up .plug up the over flow When water gets to edge of tub lip look fore leaks then release stopper and finish looking for leaks . YOU HAVE A LOT TO DO! Good Luck!!
Dec 02, 2009 | Home
Arrow ET200 nail gun only put nails in 1/8 of inch.
This electric nail gun does not have much power. Try shorter nails and softer wood. You need a pneumatic nail or staple gun for medium or heavy work. I have both a nailer and stapler and neither are very good.
Jul 23, 2009 | Arrow ET200 Electric Brad Nail Gun
Water flow into machine dribbling - Fisher and Paykel GW712 (AU)
The first thing that needs to be done is to disconnect the fill hoses from the back of the machine. Once disconnected, look at the inlet valve screens and check for blockage, if clear, open the water valves and check for water flow through hoses, if not clear, clean screens at fill valve, reconnect hoses & check for operation. If the problem remains, then the problem is with the machines fill valve & it would need to be replaced
Apr 30, 2009 | Washing Machines
Pbh 2200 re hammer action drill
hi
try to figure out how the switch operation mode works and put back together right.
bye savumihai71
Oct 13, 2008 | Drills
Whirlpool oven door
Push the hinges out till they click once. At this point, get your nails or screws ready. Use a screw driver and wedge the hinges further apart. When you see the hole in the hinge appear, put the nail in it to hold it open. With both done, drop door in place; open door slightly, and remove nails.
Oct 17, 2007 | Ovens
RTO Genova Water Hammer Muffler Plumbing Universal Pipes Logo
94 people viewed this question
Top RTO Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a RTO Plumbing Expert? Answer questions, earn points and help others
