Question about Alpine MRP-M500 Car Audio Amplifier
Brand New MRP-M500 light is on but there is no sound
I have this amp hooked up to my rear speakers and a 12 inch 2 ohm subwoofer. When I turn on my stereo, the light on the amp turns on but no power goes to the subwoofer or the rear speakers. I cheched the fuses and they are all fine.
  • sbaker2204
    sbaker2204 Mar 18, 2012
    I had the same problem when I installed that amp in my car. I have a '07 Toyota Corolla and I just retro-fitted the new amp where the older Alpine amp(MRD-M301) already was. The amp was on, the light was lit, but there was very little sound coming from the subwoofer(SWR-1243D). I say little because if I cranked up the gain and the bass boost you could hear a little bit of sound. I started to think that the ground I had wasn't good enough. I screwed the ring terminal at the end of the ground wire to a sanded off part of the trunk (bare metal, no paint). I think the metal isn't the best for grounding. It's like an aluminum alloy of some kind. Very Soft. I think I will get the Kenwood KAC-8105D and see how that works. Same specs as the MRP-M500.
    Guru:
  • 1,326 Answers
Try making sure your sound input to the amp is good (could be a bad output from the radio or RCA cable), could also be a bad input from the amp, bad outputs from the amp or even a bad sub. You have to check each of these and eliminate the problem. I would make sure you have a good audio signal to the amp first.
Posted on Sep 06, 2009
  • sbaker2204
    sbaker2204 Mar 19, 2012
    The first thing I checked was the signal flow. But everything worked with the older amp so why didn't it work with the new amp.
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
Popping noise
Check the sub with a multimeter. It should read the ohms it is rated at when you hook it to the positive & negative inputs. It its off your coil if bad.
Mar 16, 2013 | Alpine SWR-1241D Car Subwoofer
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
I hooked up a 2-Ohm dual voice coil 800 watt max 12" Kicker CVR subwoofer and 4-Ohm single voice coil 1000 watt max 12" Kenwood KFC subwoofer to 1000 watt Kenwood Ampilifer. After hooking it up, the Kicker...
off the same amp? you have two way different sounding speakers man. you can buy 2 identical speakers from the same company and brand and series and they will play differently every time. you have 2 speakers with nothing in common so you will hear a difference and maybe interference because of the different ohm levels.
Apr 14, 2010 | Kicker CVR12 Car Subwoofer
Subs cut out at low volume no matter the settings
I'm not a complete audio expert but it sounds like somethings over heating or you have a blown out put bridge.
Jun 20, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
May 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
12 w 3 v3 2 cut off
Again as I have stated in my other answer to you. You can not wire two SVC 2 ohm subs to acheive a 2 ohm load. more than likely you are running your amp at 1 ohm mono and this is why it is clipping and shutting off.
Jun 19, 2008 | Jl Audio 12W3 Car Subwoofer
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Alpine MRP-M500 Car Audio Amplifier Logo
554 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
