1999 ford escort a/c compressor not engaging freon level good.Checked fuses all good,
  • 1,144 Answers
Check the pressure switch.
http://www.autozone.com/autozone/ymme/ymmeYear.jsp?_requestid=304737
Go to this web site and fill in your auto info. Then look for the D-I-Y instructions.
good luck
Posted on Sep 11, 2009
Hello, i have a 98 ford escort lx, no power to a/c compressor, replaced high and low pressure switches,checked to compressor, replaced orfice tube, put freon, checked pressure (but its high), checked a/c...
There is a red wire going to the AC clutch, if you apply direct 12volts will it engage? If so, the constant control relay module (CCRM) could be defective. Hope this helps.
Jul 04, 2011 | 1998 Ford Escort
2000 ford escort replaced a/c compressor cant get a/c compressor to engage has freon but no power to comp ?? help ??
this is common if the fuses are good then you have a bad relay, this relay is called a relay module and it has a few relays in it and has to be replaced as a unit, this is located under the air filter housing, heres a picture of it to help you locate it. hope this helps.1406de6.jpg
Oct 27, 2010 | 2000 Ford Escort
1999 Ford Escort - the fan is blowing but the air is no longer cold. How do I know if it just needs freon or if it is a bad compressor?
If the compressor is not engaging (the center is not spinning) then it's likely that the r134a is low in the system
Add a an or two to make it work better.
Also, make sure the radiator fan goes on when you turn the a/c on.
Good luck to you.
Jul 05, 2010 | 1999 Ford Escort
Ac compressor clutch is not engaging,there is no juice to the wires going to the compressor. the ac switch on the dash has power. fuses are okay
Dear Madam or Sir,
this concern is prpbably due to a lack of coolant. There is a pressure sensor monitoring the system pressure of the A/C system that will interrupt the activation of the A/C compressor to prevent it from being damaged.
If there is not enaugh coolant, the system pressure will drop below a fixed threshold level and the compressor protection circuit will activate.
So you should have the coolant level to be checked at the shop, if it´s OK, put an eye on the pressure switch itself :)
Jun 27, 2010 | 1999 Ford Escort
My ac is not working. I have checked the fuse and the system is charged. Any help would be great!
revising downward the switch is in the wrong filter if you do not connect the compressor or missing freon the system does not connect the compressor ...
Jun 22, 2010 | 1999 Ford Escort
2002 Ford Expedition Eddie Baur Edition. Turn A/C on, no cold air. Could be freon but I am not hearing the compressor engaging. That bothers me. I should hear and feel it engaging. I have the auto. climate...
Check the fuse and relay for the compressor clutch. The clutch electrical winding could be open--check at the clutch electrical connection for 12 volts when the system is turned on. There is an interlock switch that prevents the compressor from being turned on if the system detects low freon level. Have that checked first, then worry about the electrics second. Hope this helps!
Jun 06, 2010 | 2002 Ford Expedition
I have a 1998 ford escort. The system has been evaced and freon added, also the compressor replaced. The compressor will engage.
Your trying to get the AC to cool and it won't because the orfice tube may be stopped up. during the flushing procrdue did alot of **** come out( broken compresser parts if it flushed good and you put on the new recieved dryer that the warrentee of the compresser requires. and it doesnt coll at al the condenser is stopped up. You cant unstopp them just install a new one evacuate and recharge make sure the fan blows hard and your done
Aug 18, 2009 | 1999 Ford Escort
1999 ford escort and the A/C stopped
Have the AC compressor checked.
Jul 17, 2009 | 1999 Ford Escort
A/C compressor on a 1998 Ford Explorer XLT 5.0 V8 not engaging.
Low pressure in the system and the clutch will not engage. The low pressure sensor is on it for a reason.
Apr 27, 2009 | 1998 Ford Explorer
Heating & Cooling Logo
250 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
