Question about GE Kitchen Ranges
GE True Temp flat top stove - heating with switch off
When i plug the stove in, the hot light is immediately coming on without even turning on a switch. one of the burners seems to be getting power to it and is warm without the switch on. Any ideas?
This happened recently to my stove... heard a funny sound and then the burner I was not using suddenly started heating up with the switch still in of position. It appears that the problem is the burner switch. I've bought a new one...however I didn't note the order of the wires before removing the old one... and now can't get the new one hooked up right! Part is only around $25.00.. just be sure to mark where the wires go before unplugging them.
Posted on Sep 19, 2009
GE true temp flat top stove/oven isn't working at all, there is power to it, if you turn the burner dial on the clock/electronics turn on but nothing works. turn dial off electronics/clock turn off
sounds like you are missing one leg of the 240V power supply... first thing is to reset the circuit breaker. Then, meter how many volts you are getting at the terminal block where the power cord bolts on... Help Me Find My Model Number RepairClinic com, GE Terminal Block WB02X10606
Jul 26, 2016 | GE Kitchen Ranges
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
I have a GE XL True Temp gas range/oven. None of
your stove must be plugged in for the auto-pilot to work .do you hear a ticking noise when you turn on a burner?
Oct 07, 2009 | GE JGBP28 Gas Kitchen Range
GE True Temp oven won't turn off.
The sensor is a part number WB23T10002 and goes for about $60. The paper inside the control area of the oven will state the normal resistance values of it. (probably about 1080 ohms at room temp, about 2650 at clean temp.) If you cut a lead to it, you would just get a F3 code, and if you cut the other and wire them together, just get a F4 code, so that wouldn't help diagnose the problem, but if you could use an ohm meter on the probe it would. BUT the oven should not come on without it being set to bake, SO I conclude that the ERC is indeed the problem (with the welded electrical contacts), which is a part number WB50T10043 which might go for about $125 or so. If you are careful when you replace it, you can probably peal the faceplate (part # WB27T10125) off and reuse it, so you should just need the ERC.
May 05, 2009 | GE Ovens
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
262 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
