Question about Canon PIXMA MP620 All-In-One InkJet Printer
PIXMA MP620 Installation Problems
Want to connect to the PIXMA MP620 printer using wireless. I connect printer to the laptop with the USB cable. Dialog box changes: “Printer recognized, wait for installation to complete. I wait for 10 minutes. Message appears: Can’t connect to printer . . . Re-installed several times on T60p laptop and Dell laptop. Get the same results. Anyone has an answer?
Canon MP620 cannot detect a memory card or USB flash drive for saving
Canon MP620 problem, not showing up at all - Windows 7 Help Forums
www.sevenforums.com > ... > Hardware & Devices
Apr 29, 2012 - He's got a Canon PIXMA MP620 and we're trying to get it to connect to his Windows 7 laptop. ... Basically, I started off with no trace of Canon in the laptop.Then, using the setup disc, I followed all the instructions up to actually connecting the printer to the laptop. Problem with wireless Canon MP620 printer connection Solved ...
Jan 26, 2013
Problems installing Canon MG6220 Wireless Printer in Win 7 x64 ...
Aug 28, 2012
Cannon PIXMA MX870
Feb 14, 2011
cannon mp620 printer
Mar 28, 2010
More results from www.sevenforums.com
Nov 04, 2015 | Canon PIXMA MP620 All-In-One InkJet...
I have a Pixma MP620 connected to Win7, but have wireless access and also use MacBook. Cannot print wirelessly to printer from Mac..........have a solution?
Make sure you have the drivers installed - while there are possibly compatible drivers that came with your MacBook, it may not work properly out of the box.
Download them from http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp620#DriversAndSoftware. Make sure you choose "MP Drivers for Network". Do not install yet, but open the package file.
The next step requires a USB cable. You need to connect the MacBook to the printer and only then start to install the drivers by clicking the Setup icon.
You should do the 'Easy Install', if you get asked for it. When the installer asks to restart the machine, do so.
Once the machine restarts, you'll get a window for the 'Canon IJ Network Tool'. Click for 'Lan Connection', and then OK.
You'll want to click the 'Register Printer' button next. You may get a 'Cancel Setup' screen, just cancel that out.
The next part requires waiting. After a bit - really, it was different for all three computers, so I can't say how long - you'll get an 'Add Printer' screen. Choose 'Canon MP620 series', and click add.
On the Canon iJ Network Scanner Selector screen, set the pulldown for "Canon MP620 series Network', and then click the MAC Address (there should be only one) and cick 'Apply'. Make sure the check mark is displayed, then click exit.
That should register your laptop as allowed with your printer. Turn off the printer, disconnect the USB cable, turn the printer back on and you should be able to use it.
Apr 02, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Where can I buy a replacement USB cable,power cord and setup CD-Rom and Document kit for a Canon Pixma MP620, I have the printer just not the above, ( got lost in move) thanks!!
The USB cable can be purchased at any office store or Wal-Mart. The software can be downloaded free from Canon. Here is the site for your printer:
Canon MP620 Downloads
Select the correct operating system and download to your Desktop.
As far as the power cords you may need to Google MP620 Power Cord for some online choices. Here is just one that has the power cord and USB cable, as well as ink:
http://www.abacus24-7.com/Canon-PIXMA-MP620-Wireless.htm
Thanks for using Fixya. If you need additional help, just Comment back.
Wayne
http://www.directron.com/canonprinter.html
Sep 24, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Canon mp620 not connecting to my wifi laptop
This could happen if the port that you are using is not the right one.
When you are using a printer wireless, you need to use the Standard TCP/IP port, to setup a printer port, do the following
Right click on printer icon, select properties
Click on Add port, select new port
Enter the IP address of the printer, this can be obtained by printing the settings page from the printer.
Note: please setup a static IP for your printer, else everytime you restart you may endup with a new IP
Let me know if this works,
Jul 29, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Canon MP620 is not recognized by PC
Make sure you do not have it plugged in before you start the install. Also for the next install attempt, plug the cable in to a different USB port than the one you;ve previously tried.
May 23, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Wireless hookup mp620 without computer
You cannot connected to a computer through Bluetooth. You can use their usb based bluetooth to connect the printer to other devices like your camera or camcorder.
Feb 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cannot install Canon Pixma MP620 drivers
printer propperties/connections/add...
add a new Canon BJNP port
this solver the problem for me
Nov 18, 2008 | Office Equipment & Supplies
Printing from my laptop
I would need more information to help you with this problem. Do you have the correct and up-to-date Canon drivers installed in your laptop? Is the Canon operating as a wireless unit, or is it connected to the computer via USB cable? If wireless, is the Canon setup to operate wirelessly? If on a USB cable, is the USB port properly configured? Is the USB cable plugged in at both ends? The easiest thing to try is to go to:www.usa.canon.com. You can find downloadable drivers, installation instructions, and other documentation, free. The Canon drivers use an INSTALLATION WIZARD program to guide you through the printer set-up process.
Sep 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP620 All-In-One InkJet Printer Logo
309 people viewed this question
old marine
old marine
