Question about Konica Minolta bizhub C250 All-In-One Laser Printer
The machine say stopping/deleting however it is taking a real long time and seems to be frozen
Hot water not running to machine just the cold water
Try switching the hot and cold hoses. See if the hot water works. Sometimes the gate gets frozen, other times the hot is so slow it seems to not be working, similar to when it takes a long time to get hot water in the sink.
Apr 19, 2017 | Washing Machines
Whirpool ice machine not getting water
If your certain the line isn't frozen. Then your valve is bad
Apr 20, 2015 | Whirlpool Refrigerators
Why is the needle frozen ? It seems to have a clutch knob (largest knob at upper right) but hand tight does nothing
honestly, this machine is the WORST machine I've owned!
I bought it to do quilting, but it has been one problem after another, endlessly.
Right now, I am trying to get the bobbin thread to pick up, and it just doesn't want to.
Wish I had an answer, but right now, the real answer is to buy a Brother sewing machine!
Nov 20, 2010 | Singer Featherweight 132Q Mechanical...
My computer seems to freeze. it has frozen severa...
You computer seems to be performnig slow, you can download CCleaner, and clean the garbage files.
You can go to Start-Run-%temp% and delete all the files.
You can go to Start-Run-Temp and delete all the files
You can run disk cleanup and select all the options which is available in the list.
You can go to your Internet Explorer-Tools-Options-Advance-Reset
You can also uninstall any unused program and delete the files you dont need.
These will get your computer back in track.
Regards,
Shrey
May 14, 2010 | Computers & Internet
Deleting paused and frozen there. Cannot use the
it seems you might need to rest teh PC..
Once you have done that and assuming you are running windows pls do the following (while the printer is OFF)
1. Go to "Start", "Run"
2. Type: CMD
3. press "Enter"
(now you should be in a DOS terminal window)
4. type: net stop spooler
press "enter"
5. type: net start spooler
press "enter"
6. type: exit
press enter
Turn on the printer...you should be clear now :)
Cheers,
Ed
(If this works for you, please grade this response)
Nov 06, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Laptop is frozen on logging off screen. How can I finish the shutdown. Control/Alt/Delete won't reboot.
I have an asus pc 1000hd that does this every now and then. I hold the power button down and the whole machine shuts off after a few seconds. Either that or you can take out the battery, wait a few seconds and then reinsert it
May 28, 2009 | Acer Extensa 5420-5687 Notebook
Gaggia Titanium
Do you mean the brewing unit you not can get out?
Jul 12, 2008 | Gaggia Titanium Espresso Machine
Frozen hard drive
If you have a Thomson DT16300, here's a handy fix that address freeze ups, lack of reception and problems on your Hard Disk:
goto MENU screen
goto SETUP screen
goto HELP screen
At HELP screen, Enter 1397 - this accesses the engineer panel - you can reformat the HDD in this menu - you will lose all recorded programmes and planned recordings but it clears locked or corrupted files
OR - at the HELP screen, press the GREEN button
On the lower half of the screen youwill see 3 options:
Blue - Reformat HDD - clears all the memory/HDD - useful if you have a corrupted file - you will lose all recorded programmes though
Red - reset the whole box to factory settings - good if you have a locked box or reception problems or cannto scan for new channels. It goes back to when you bought the box, so you will have to input favourites and planned recordings again
Yellow - Software revert - allows you to go back to the previous software driver - you may lose new functions, but you can always restore it back again using the same feature
Feb 15, 2008 | Thomson DPL909VD System
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
