Question about Whirlpool Dryers
Keeps blowing thermal cutt-off fuse
The dryer keeps blowing the thermal cutt-off fuse.
  • Whirlpool Master
  • 1,606 Answers
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Posted on Sep 05, 2009
Lg dryer keeps blowing thermal fuses we have checked the thermostat and the element all have continuity
The thermostats (outlet and on element case) can still allow the heat to go to high, restricted airflow will also cause them to go.
Jan 31, 2015 | LG DLE3777 Electric Dryer
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
My dryer keeps blowing the thermal limiter fuse or switch,what ever it is called.why?
Hi candwloc..
If the thermal fuse /thermostat overheats the dryer will not operate.
It's located on the blower housing and it cannot be reset.
A vent clogged with lint can cause the dryer to overheat and keep blowing the thermal fuse/thermostat.
You can test it with an Ohm meter or continuity checker, if no continuity, replace it.because it is faulty.
Please take time to rate me
Jul 24, 2011 | Frigidaire FEQ332E Electric Dryer
Thermal fuse keeps blowing. Dryer heats up too
The problem will be either your vent is stopped up or the cycling thermostat and the high limit thermostat are bad. If the vent is clean, both the cycling thermostat and the high limit thermostat are welded closed. Both are supost to open to avoid over heating. Go to www.partselect.com and enter your complete model number. It will bring up diagrams of you machine. From there you can find the parts ans also order them if you want to. Good luck.
Nov 25, 2009 | Cars & Trucks
Keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Mar 09, 2009 | Whirlpool LGV4634JQ Gas Dryer
they will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
Nov 25, 2008 | Amana ALE331RAW Gas Dryer
You see the other switches next to the thermal fuse? you need to change these too if you have a problem with the themal fuse blowing out repeatedly.
Aug 09, 2008 | Kenmore 64902 Electric Dryer
Thermal Fuse
First of all stop replacing the fuses and using the dryer it could burn down your house. The problem is the vent is clogged (not necessarily in the dryer) make sure also that the vent flex is not excessively long behind the dryer and is not kinked when the dryer is pushed back.
Nov 19, 2007 | Whirlpool LEN2000PW Dryer
Dryers Logo
422 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
