Question about Apple Cinema Display 23" HD Monitor
How to replace the panel from a cinema display?
  • 2 more comments
  • daniel_bigay Sep 05, 2009
    I need to know how to replace the screen panel from a 23 apple cinema display?
    Thats right I plan to take apart the cinema display and replace the screen because it cracked. Can I do that?
    How to take apart an apple cinema display and replace the screen? Because my screen is broken. Is it posible? And can I put it back together? Please help me I dont know if to buy the replacement part.
    I need to know is it posible or not to take apart a cinema display 23 and replace the screen for another screen? because mine is broken. Please let me know
  • Apple Master
  • 497 Answers
1. First remove the plastic.
2. After removing the plastic ends, remove the two other metal pieces that the plastic ends were attached to.
3. Turn the Monitor upside down and you will see two small tabs on each end.
4. Just pull those outward. They don't move far, but that releases the bottom seam of the Monitor.
5. Carefully pull the two pieces apart. Remember that you will put a crease on the front of your Monitor if you open it too much.
6. If you have a tool to remove the power cable great, but if you don't you can carefully pull the cable through the hole.
7. Then the whole LCD with all the boards can be removed and serviced.
Good Luck!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Sep 06, 2009
  • Apple Master
  • 13,433 Answers
Panel? As in the display panel itself that shows the picture or what exactly? Do you already have the replacement as I don't know if its worth it.
Posted on Sep 05, 2009
  • Ekse Sep 05, 2009
    You need to open the case of the display, the power board and other board are probably screwed to the panel, if the new panel does not include them, then unscrew them and place them on the new panel.
    The panels itself have a circuit board and few back light wires, do not remove those unless you really have to.
    it is very simple and straight forward job. The case will be held closed with screws or with plastic clips on the sides of the case, or both.
    all you need is a set of screwdrivers and a case opener tool would be recommended not to ruin the plastic on the sides of the case.
  • Ekse Sep 05, 2009
    I don't feel its worth it. yes you can do it if you wish and you have the money go ahead. or you can take the part and the display to a professional.
    Or buy a new 24" display
  • Apple Master
  • 19,396 Answers
Apple cinema flickers when warmed up
  1. Adjust the brightness setting. The brightness control (marked by ) is under the right front edge of the display.
  2. Calibrate the monitor using the Calibrate option in the Monitors control panel.
  3. The flickering could be caused by interference from a nearby power line, a fluorescent light, or an electrical device for example, a radio, a microwave oven, or another computer. Try relocating nearby electrical devices, or moving your computer and display.
If you are still having problems with your Apple Cinema Display, please consult Apple support here:
https://expresslane.apple.com/GetproductgroupList.do?PRKEYS=PL117
Jan 23, 2011 | Apple Cinema HD Display30" Flat Panel...
Power connector on cinema display is damaged. Can it be replaced?
Hello, GREAT NEWS!!! Yes you can replace it. Try going onto Ebay and punch in: A1097 Apple cinema display power ac adapter 90W 23" LCD.
May 05, 2010 | Apple Cinema Display 23" HD Monitor
20" cinema display will not power up
check the cable connected to power supply, try to mve it up and down while trying to push the power switch, just a little updown, if it flickers the then you need to change your cable, see also if your cord had it's own fuse on the plug itself, have it check or replace
Nov 04, 2009 | Apple Cinema Display Flat Panel Monitor...
Apple Cinema display goes BLACK after start-up
My G4 has a ADC & VGA on the same card. The VGA works but the ADC, is doing the same thing as you described. I am searching the web, and can not find an answer to this problem. George 3/21/2010
Aug 03, 2009 | Apple Cinema Display Flat Panel Monitor...
Dim 20" Apple Cinema Display
Double check you power cord and try switching plugs.
sounds like its not getting enough power or a CCFL is going or is out and you need to get it serviced if thats the case.
Do not attempt to repair this your self Monitors usally have there own power supply built ind can store massive amounts of energy and will cause serious injury or death.
Jan 30, 2009 | Apple Cinema Display Flat Panel Monitor...
Apple 23" cinema display
thats supposed to mean theres a faulty powerbrick, however i have the same problem on mine and replacing that didn't solve it
Oct 28, 2008 | Apple Cinema Display 23" HD Monitor
Replacement LCD for 20
You might try http://www.preowned.com/
Right now it says to call to see if they have the part. They are probably not going to be any cheaper, but it's worth a shot.
Other than that keep looking on eBay.
Nov 09, 2007 | Computers & Internet
Apple Cinema Display 23" HD Monitor Logo
104 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
