Turn on the Bluetooth-enabled
device and enable it to be in "Discovery" mode. Check the owner's manual
of the device to learn how to put it in "Discovery" mode.
Press "Menu/Ok" on the LG Rumor2, which is the middle button on the phone.
Press " * " to access the settings menu.
Press "1" for the Connections menu.
5
Press "2" for the Bluetooth menu
then press "1." Press "Yes" when prompted to turn on the Bluetooth
feature. A list of available devices appears in the menu.
6
Highlight the listed device, which should be showing.
7
Click "Ok."
8
Enter the passkey provided in
the owner's manual of the Bluetooth device. The standard passkey is
"0000." The Rumor2 is now paired with the Bluetooth device.
9
Press the "Call" key on the
phone or the "Call" button on the Bluetooth device to answer calls
through a Bluetooth headset while paired.
Insert a microSD card into the slot on the right side of the phone.
Connect the phone to your desktop with the USB cable.
Select "Transfer Music" on the phone by pressing the "OK" key after highlighting "1 Yes" on the display.
Go to your desktop and use
Windows Explorer, which will have now opened up, and you can drag and
drop files from the desktop to the phone just like another directory.
Use the Rumor Bluetooth to Connect to Your PC or Other Bluetooth Device
Set your secondary Bluetooth device into the pairing mode.
Open the "Tools" menu on your
phone by first making sure it is in the standby mode and the slide is
closed. then press the "OK" key and select "Tools."
Select "Bluetooth" and press the
"OK" key to choose "Pair with Hands-Free." If "Bluetooth Wireless
Technology" is turned off follow the prompts to turn it on by pressing
the "Left Soft Key."
Highlight secondary Bluetooth device on the list of found devices and press the "OK" key.
5
Enter "0000" pin code and press the "OK" key to initiate the pairing process.
6
Enter the device's name and press the "Left Soft Key" for "Save."
7
Connect to your device by pressing the "Left Soft Key."
Not sure if you have paired your bluetooth with your phone yet. Hold your bluetooth button down untell it flashes (usualy blue and red) continuously your phone should then find your bluetooth then it will ask for a code. Usualy the code is 0000. If not make sure your bluetooth is turned on:)
To pair your phone with another Bluetooth device, perform the following steps:
1.
Press the Menu/OK key, select Settings/Tools, select Tools, select Bluetooth, select Add New, and then select Search. Your phone displays a list of discovered in-range Bluetooth devices.
2.
Select a device, and press the Menu/OK key.
3.
Enter the passkey, and press the Menu/OK key.
Turn the headset off.
Set your rumor to find new devices, then immediately turn the headset back on. The devices should pair together. If the rumor asks for a code, the code is 0000.
turn bluetooth on your phone on. then on your bluetooth headset hold the power button for about 10 seconds or until you see the bluelight on steady. next on your phone in the bluetooth section klick ok on the search for device option, when you found the bluetooth with your phone it will ask if you want to use that device, klick yes, and it might ask you for a code, enter four zeros "0000" and that should connect automatic.
it needs to see the jabra..could be a timing issue...start phone (charged) start headset (charged) phone should announce it has found a device *would you like to connect?* message.....another thing..in tools you need to tell phone to look for bluetooth devices (on)
