Question about Dell A960 All-In-One InkJet Printer
Page blank Dell A920
Copy, scan, or print job nothing comes out on the paper. even the test page comes out blank.
tried all the troubleshooting things,....nada....
thanks
pastorm
  • 98 Answers
SOURCE: printer acts like it's working then produces a blank page
Try to print first a self test page on the printer. Does it print a blank page also ? Do you have good or new ink cartridges in the printer ? Let me know.
Posted on Aug 01, 2007
map9966
  • 2351 Answers
SOURCE: Printer ejects blank page
For the A960 click the link below.
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?c=us&cs=19&l=en&s=dhs&SystemID=PRN_ALL_A960
If for what ever reasin this site does not help you. You can chat with a Dell tech for free. You will need your Service Tag number. Click on this link for chat. http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_us_options?c=us&cs=19&l=en&s=dhs&~tab=1
Posted on Jan 31, 2008
SOURCE: Prints Blank Pages
i was having these same exact problems then i looked at my old ink cartridge and saw that the blue tape was off and that i hadnt taken it off my new one i was trying to print with.!!!
Posted on Apr 18, 2008
  • 53 Answers
SOURCE: 1720dn dell
Normally to fix a printer that is printing gibberish, uninstalling and reinstalling the print drivers will fix this issue. Another thing that can contribute to gibberish print is using a USB cable that is too long.
With this particular problem (prints Zen), one solve is to uninstall any Dell toner management software. This is particularly true if you are running Vista and hooked up by USB. To uninstall the toner management software (Vista OS), go to control panel>programs>programs and feature>uninstall a program. From this list choose Dell software, choose a customized uninstall, and then choose anything that has to do with Dell toner management.
Posted on Jan 08, 2009
T-Mania
  • 42 Answers
SOURCE: A920 printer has ink, feeds paper, but pages come out blank
If this is a new printer have you removed the sealing tabs inside it.
May be caused by bad drivers. Check the vendoes site for the latest drivers for your operating system and see how it goes.
Did it previously work and after swapping something start failing?
Posted on Mar 19, 2009
Printing jobs are coming out blank
Does this happen if you make a copy? Or print any internal form meter count sheet demo page etc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 14, 2014 | Konica Minolta bizhub C250 All-In-One...
My Dell A920 prints blank paper.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 01, 2012 | Dell A920 InkJet Printer
I have an HP 4345 MFP that's printing nothing but blank pages when copying, sending a print job to the printer. Im not even able to print the config page. All comes out blank. Does anyone have any idea...
if you are tec guy?
do half test page test find any image created on catridge drum, if no image found then
Check laser scanner assembly shutter fully operating or not while catride access unit closed, if unable to check, remove the shutter from laser scanner assm
Increase toner density
set factory settings,
If image on drum no print on paper, check transfer roller, contacts, if dirty replace T.roller, no result replace Power supply board..
Sep 09, 2011 | HP LaserJet 4345mfp Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
My printer has been printing just fine until today. It still "acts" as though it is printing, but a blank page comes out. I have replaces both black and color cartridges and have shut down the...
Have you tried running cleaning the nozzles using the software? Here is a link on how to do it:
http://support.dell.com/support/edocs/systems/A920/a920en1.pdf
just checking that you also removed any "tape" that might have been on the ink cartridges prior to installing them?
Oct 27, 2010 | Dell A920 InkJet Printer
I've never been able to print using the a920 on my computer using vista. It prints perfectly on other computers, though. It starts up, acts like its printing a page, but the page comes out blank. In fact...
u need to uninstall the drivers for the printer on ur vista computer,.. go to the following link and download latest vista drivers..
it will work..
Dec 20, 2009 | Dell A920 InkJet Printer
Blank paper syndrom
Can you do a simple color or b/w copy job? If yes, the ph is OK and you might have to reinstall the drivers (delete before that the old ones).
If you cant see any copy job (blank paper) you should change to original carts and run the manual cleaning procedure twice. Wait a few hours an try to do the printing again. You might have to run the cleaning procedure twice again!
May 12, 2008 | Brother DCP 130C All-In-One InkJet Printer
Dell A920 Paper will not go into the printer without a jam.
check cartrages plz your cartrages ok after you clean pickup roller i hope your pro. solve
Dec 20, 2007 | Dell A920 InkJet Printer
Printer acts like it's working then produces a blank page
Jul 31, 2007 | Dell A920 InkJet Printer
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
Dell A960 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
