Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
My G1 phone says paired but not connected to my HS850 headset. how do I get it to connect?
  1. From the main screen, press the Menu button and choose Settings.
  2. Select Wireless & networks, then Bluetooth settings.
  3. Scroll down to the device you want to delete. Press and hold until a popup menu comes up.
  4. Choose Unpair. This will make the status change from “Paired but not connected” to “Pair with this device.”
  5. Reboot the Droid. When it comes back up, the bluetooth device will be gone from the list.
  6. Rescan and connect
Posted on Apr 08, 2010
I have tried everything . My Motorola Hs850 will not connect. It keeps indicating that the connection failed
Firstly, make sure you have enabled Bluetooth on your phone or whatever device your using the headset with. The default setting off, so go into your phones set menu and enabled Bluetooth.
You'll then need to 'pair' the headset and phone.
1. Ensure the headset is turned off (indicator light not blinking).
2. Press and hold the Call E button for 4 or 5 seconds. The indicator light will initially flash, but continue to hold down the button until the indicator light is steadily lit.
If the indicator light is flashing or not steadily lit when releasing the button, repeat both steps 1 and 2. Hold the Call E button for 4 or 5 seconds.
3. Enable Bluetooth on your phone and get to 'search for devices' it should find the headset.
4. Select Motorola HS850
Select OK or Yes to pair your headset with your phone. Enter the passkey: 0000 Select OK. When your headset successfully pairs with your phone, the indicator light changes from steadily lit to flashing.
Hope this helps. Oh and make sure your phone actually supports the headset!
Jun 13, 2011 | Motorola Mobility HS850 Consumer Headset
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Instructions
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
Feb 23, 2011 | Motorola Mobility HS850 Consumer Headset
Can't connect a motorola hs850 with a samsung m520.
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Jun 23, 2009 | HTC G1 Smartphone
People can hear me hs850
try re - pairing the headset with your phone. Delete the older paired profile from your phone before re pairing.
Good luck
Aug 20, 2008 | Motorola Mobility HS850 Consumer Headset
How do i connect motorola hs850 with lgcu720 (shine)
1. With the headset’s boom closed,press and hold the Multifunction
Button E until the headset indicator turns on (about 3 seconds).
2. Release the button, then open the headset boom.
3. The headset indicator remains on.
4. Perform a device discovery from the phone.
5. Select the Motorola HS850 from the discovered devices list and confirm following the on screen prompts.
6. When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone.
The device ID is now stored in the phone’s memory.
Pairing is successful when the headset indicator flashes 10 times
rapidly.
Hope this helps
- Ted G.
Jun 25, 2008 | Motorola Mobility HS850 Consumer Headset
Won't connect to cell
When you're in a call w/the headset paired to the phone, if you press the options menu on the phone, it should say "Switch to Phone". If it doesn't then you're paired, but not using the headset. If it shows "Switch to Headset", click that and you'll be good to go.
May 09, 2008 | Motorola Mobility HS850 Consumer Headset
I am trying to pair my hs850 to my nokia n95 8gb
To emu144,and others if passcode wont work completely remove all bluetooth connections from phone and try repairing make sure headset has a good charge
Apr 27, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola HS850 Headset gone silent
I bought a new HS850 and guess what, I got this hearing problem on the very first day ...phew ! I did the pairing with my Motorola A1200 phone and it worked for once, even the sound was coming in the earpiece and then I put it to charge for the first time and once done, I again started it up and it got connected with the phone and after that there was no sound in the ear piece. I was going nuts....about what could be the problem.
So i decided to delete the earlier paired profile from my phone and do the pairing again and guess what...It Worked....:) So you can try that out too....
Dec 06, 2007 | Motorola Mobility HS850 Consumer Headset
Pairing Motorola RAZR with the HS850
No, living outside of your cellular "home area" has nothing to do with the bluetooth pairing. You're problem is a common problem. Lots people have this problem you are not alone. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Aug 02, 2007 | Motorola Mobility HS850 Consumer Headset
Can't connecto to headset again...
You are not alone in this endeavor. A lot of people have this problem. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
May 09, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
563 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
