Question about Toshiba 61H71 61" Rear Projection Television
Whats the diference between version letters on power board
Whats the diference between version letters on pd0074 board can u replace a version c with an A
  • 476 Answers
The parts available list for your 61H shows PD00764 version C as the deflection board for this particular model, it might be that version A would go to a smaller size screen model, toshiba manufactured a 43" and a 53" with this 61" also. So back to your question, all I can say is , if you already have the A version I would compare to version C and keep in mind the connectors(plugs) make sure they are a like, I would imagine that the only diference you would see in the picture would be picture width and vert size. A good idea would be to contact a module rebuilding company(tristate module for example) and get their opinion.
Posted on Sep 05, 2009
Yahoo disabled my account for no reason iam using this email account for 9 years i don't know what happen i have so much important emails on it im really disappointed of yahoo (marwa_anas@yahoo.co
hello,
not all are lost,please try the following:
1.instal java script on you pc(latest version)
2.try to connect with all know browsers(explorer,firefox,chrome,,,,)
3.try from a diferent pc
4.try diferent pc ,diferent location,diferet ISP
Feb 29, 2012 | Yahoo Mail
My dell 1525 has a blank screen it has happened before I had to take out the battery, then replace and hold down either fn key and a letter or the shift key and a letter. Can you help?
Press the "FN" and "F8" keys at the same time.
Pressing the keys each time has a diferent result.
One time- display is on external monitor
second time: display is on both laptop and ext. monitor.
third time - back to laptop.
Note::
Check for cracks along the LCD screen.the 1525 top is too soft, and flexible. The rubber bumpers are spaced too far apart, causing the lid to flex when closed ...cracking the edge of the LED board. Even with lightest pressure it would be possible for this to happen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 10, 2011 | Dell Inspiron 1525 Laptop
When I started computer. Display Problem
are you useing onboard video or card if card try diferant card that you know that works.and if on board go in tocmos disable video on board then get new card. or try diferant mon.jim
Nov 18, 2010 | Intel Motherboard
Antenna wire is loose... I need a wiring diagram to enable me to rewire to correct location
It´s best to use Google to find the service manual, note that there are many diferent hardware versions of the WRT54G\GS\GL, wich are slightly diferent from each other, you can find the hardware version on the lower part of the router.
Aug 18, 2010 | Linksys Wireless-G WRT54G Router
Lost info for my board no cd no box how can i tell you what motherboard i have System Manufacturer AWARD_ System Model AWRDACPI System Type X86-based PC Processor x86 Family 15 Model 2 Stepping 9...
look on the mother board inside the computer you should see letters and numbers in bold white...this should be *********** board model....asus, intel. nvidia. etc. then you can go to the manufacturer site online and download the the drivers and manual for that board model.....
Dec 09, 2009 | Computers & Internet
My ps3 shut off secs after i turn it on red light blinks n beeps
Mother board failure is very common with ps3!!!!!!! If not power supply , then motherboard. You can get a tester and test all the capacitors and resistor and get a service manual to know the correct ratings of the components.
Aug 28, 2009 | Sony Playstation 3 (PS3) Console
Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Jan 04, 2009 | Toshiba 57H81 57" Rear Projection...
Rexhina_revi@hotmail.com
the normal keyboard is called a qwerty keyboard because the letters in the upper left portion of the letters spells qwerty and it would be very surprising to find out that you had a different style. As far as the power problem, you will need to order a new battery for the laptop from what it sounds like.
Dec 17, 2008 | Acer Aspire 3610 Notebook
Toshiba 50H72 problem plz help!
ok well both of you have had the same problem i did... to fix the picture problem check the circuit board pd0074 its the yellowish looking one next to the green one which has the ic's on them... ok on the pd0074 board look for fuses f470, f850, and the f851 to see if they are blown the f470 is what turns the tv on and the f850 and f851 are what protect the convergence ic's chances are they are blown.... the sound i don't know how to fix that problem but i would check all the fuses on that board to find out if one more is blown that what i did but the only thing is that i could get the actually fuses for the tv i was told by a tv repairman in my town to just take 2 wires sodder them on to the fuse and take a glass fuse and put electrical tape around them and it worked like a charm... so i hope this helps you.... the most i spent was 30 dollars for the ic's and the fuses all together and i was quoted at 450 to do what i did myself
Oct 31, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 65H81 blank screen and red blinking light....help
I don't think is any lamps.
If you are handy try to open the back of your tv, (unplug it first) don't touch anything just yet, you need to make sure you discharge any static left on the power board (the first from your left )Unplug power cord from the board. Take a heavy long screwdriver (Isolated) and lightly, touch a few parts on the board including the thick red wires that go to the lamps. Once that's done its time to put your dexterity at work. You need to lift that board (PD 0074) so that you can check some fuses like F850, F852, etc. for continuity. Mine were out. I had replaced those two and I had tv for another year. Remove the screws that hold the board. Now, this board PD0074 is connected to the next board by two white connectors and one blue. ....lift them up from one side with your finger nail. Don't unplug anything from the power board, just loose some wires so that you can lift the whole board on one edge. Get a voltmeter and set it to check continuity. Mine has a buzz. Look for them fuses if they are bad , ....replace them. (You can buy them at Partstore.com.....punch in "fuses"or "125V 2A")
In my case that was the only problem a year ago. Now I also have the same problem but this trick didn't work for me anymore. The Power Co,. messed me up big this time. In fact the problem with these Toshiba rear proj. is that when the power in your house goes out and comes back right a way in a split second and you don't have a power regulator, guess what : 'red led blinking'
In my case this time the whole power went on and off a few times within 10 sec. and by the time I got to the TV to unplug, it was to late. I think I have to replace the whole PD0074 board....and that's expensive.
Good luck
Jan 12, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 61H71 61" Rear Projection Television Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
