Question about LG RU-44SZ63D Television
I have a lg dlp projection tv that while i was watching it it just popped and shut off. thought it was a bulb so i change that but nothing. what is happening is when i turn the power button on the yellow light blinks for a minute then it turns red to standby.. can you help...model number is ru-44sz63d thank you
  • jiml19 Sep 05, 2009
    lamp did not show any problem and i did replace cover so the switch was pushed in.and fan moving. all i hear from it for that minute is a slight humming type of sound
  • 476 Answers
Lets statrt with the obvious, did the lamp that you replaced showed any type of damage(blown, broken) and when you put in the replacement lamp did you also replaced the lamp cover? or at least remembered to activate the door switch? these tvs have a starter board if everything checks out see if you get any type of activation sound whent you turn the power on, kind of a click sound and another thing to look for is the ventilation fan, is it activating when you push the power button?
Posted on Sep 05, 2009
  • jaime vargas Sep 09, 2009
    the noise could be a result of either a starter circuit problem or a worn color wheel motor, the wheel should give time enough to show a picture, usually color spot areas around the screen, the starter circuit would not. the color wheel does make a little noise when it kicks in but it should not be very loud.
I have a 50 inch Philips Magnavox LCD TV. It worked fine till the power went out this morning. Everything came back on fine except for my TV. It still receives a signal but it has no picture and no...
The projection bulb came on,but didn't stay on mean the bulb have problems,dosen't mean projection bulb it still good.First must replace a new projection bulb to make sure for the elimation for the projection bulb is the problems.These DLP tvs require new projection bulb every 1 1/2 or 2 years by watching the tv like 4 or 5 hours daily.So there no lost there for trying a new projection bulb alway can save it for later use.The secound could be the board that call the Ballast board have problems too.The Ballast board only job it is to ignite to the projection bulb and make it work.Replace the Ballast board too,if the tv new projection bulb react the same way.
Mar 23, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
LG DLP Suspected Faulty Bulb... how to be sure?
First pull back off turn TV on watch Fan behind lamp more then likely it is going bad Fixed LG 9months ago and it was the Fan.If Fan Stops turning Lamp will not light.
Aug 06, 2009 | LG Televison & Video
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Lg RU-52sz30 rear projection tv does not go on
I have an lg dlp projection tv Model # 52sx4d-ub.I replaced the bulb,everything correctly,but no picture. LG says I have to have a tech come out to reset? Can you help.
Jan 23, 2009 | LG RU-52SZ30 52" Rear Projection...
TV made popping sound and then shut off
You need to look in your owners manual for the telephone number and order a new bulb. It should cost about $200, but they will ship it overnight and minimize your downtime.
I've replaced 2 in my WD-52525 in the last 3 years, the first one went like yours did, very suddenly, with an audible POP!! The second one was preceded by an orange warning light, which the book says is a warning that the bulb has about 20 hours left on it.
To replace the bulb, UNPLUG THE TV, remove the left speaker screen, with a philips screw driver unscrew the bulb, pull it out by the handle, then replace it with the same type, in reverse order. This is a very easy replacement that does NOT need to be done by a service technician to complete.
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
Red screen on LG 44-inch DLP
Go to this site, follow the instructions, and it might fix your problems. I did, and my tv is better than ever!
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Mar 28, 2008 | LG RU-44SZ51D 44" Rear Projection...
Toshiba 42 in 720 DLP TV MODEL HM66
You need to replace the lamp in this set. The "pop" you heard was the lamp popping.
Josh
Feb 24, 2008 | Toshiba 42HM66 42" Projection HDTV
LG RU-44SZ63D Television Logo
378 people viewed this question
Computer Repairing
Computer Repairing
