Question about Canon PIXMA MX310 All-In-One Printer
MY PRINTER PIXMA MX310 SWITCH DOESNT TURN ON AND THE FLASHING ORANGE BUTTON FOR ALARM SHOWS.WHAT DOES ITMEAN?
My Canon MX310 alarm light is on - ink reservoir is almost full. I cleaned the reservoir and have tried the above procedure to clear the alarm but it hasn't worked. How do I clear the alarm?
Dear
You can reset the waste ink tank counter yourself. Be aware that this doesn't actually empty the waste ink tank itself but it does allow you to continue printing.
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
Thanks.
Feb 22, 2015 | Canon Pixma MX310 All in One
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
MY PRINTER PIXMA MX310 SWITCH DOESNT TURN ON AND THE ALARM SHOWS. thier is no lcd displayed WHAT DOES ITMEAN?
Possible that the power supply is faulty as there can be a link failure to the display, Also it can be a failure of the display drivers, Possible fault in the display sub processor or even the main board.
You need to cross check and confirm with voltage checks on the power, display and main board.
May 04, 2011 | Canon PIXMA MX310 All-In-One Printer
What is error 5200 it shows up blinking alarm light when i turn on computer and doesnt print at all
This is a paper jam error.
Once you clear the jam press the on button for 5 seconds.
Mar 31, 2011 | Canon PIXMA MX310 All-In-One Printer
My Canon MX310 has an error code U051. I have tried 3 solutions on fixya and they did not work. One solution I get to this step and my printer will not show a steady alarm light.\r\nthe step that won't...
Error Message: Check Ink U051
This message appears when the cartridge not installed, not properly installed, or non supported cartridge is installed.
As a result the printer cannot recognized the installed cartridge.
Remedial action:
* Reinstall the cartridge properly
* Ensure that you installed supported cartridge only
* Replace the cartridge
Nov 18, 2010 | Canon PIXMA MX310 All-In-One Printer
CHECK PRINTER (5800)
Please un and re install the device drivers following link
Installing Devices on PCs and Laptops
May 05, 2010 | Canon PIXMA MX310 All-In-One Printer
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
102 people viewed this question
old marine
old marine
