Question about D-Link AirPlus DI-524 Wireless Router
I CAN NOT GET MY COMPUTERS AT HOME TO RECONNECT TO THE INTERNET THROUGH THE ROUTER
  • cystor May 11, 2010
    A bit more information about your computers and network would help, but try checking these and maybe supply some more info;
    1) Are you using cables to connect your PCs to your router or are you using wireless?
    2) If you are using cables, are the lights on, on the corresponding ports on the router where the cables are plugged in?
    3) If you are using wireless, try using a cable and see if you can connect using that first.
    4) On your PCs (XP, Vista?) go to 'Control Panel, Network Connections'
    and see if the connections are enabled and connected.
    5) What is the make and model of your router?
    A bit hard to know where to go from here without a bit more information......
    Sergeant:
  • 324 Answers
Search for any wifi connection, you will definitely see your router as 1, connect and make sure you add the security code if there is any
Posted on Sep 10, 2009
My router is not detecting an internet connection when hooked up to my cable modem. However, when my modem is hooked directly to the computer there is an internet connection
Try power cycling the router.
Disconnect the router from all computers and devices.
Power off the router. Power on the router. Reconnect the router to all computers and devices. Check the Internet connectivity.
Mar 01, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Tip
Multiple Computers on Same Network, Continual Internet Connection Dropout
After adding that second or third computer to your home network are you constantly fighting over who's using the internet connection? When your high schooler logs into his facebook chat, are you getting dropped off of your internet connection?
Or have you added a wifi router and is your whole network not staying connected like it did before you added your wifi?
These are common issues and we answer these questions often at FixYa.
Here is s a tip that will get you past the internet connection being dropped by someone else on your network attempting to log into the internet or help you get that wifi up and working with out all the cut outs and drop offs.
Follow this simple procedure and you'll be amazed!
1. Turn off everything. Turn off computers, routers, modem, printers... everything that's on your LAN (local area network) or home ethernet.
2. Turn on your wireless router next. With the ethernet cable connected to your wifi router to your modem and let it cycle up to running. If you aren't running wifi, do this with your main router. Make sure your modem and everything else is still off.
3. Turn on your modem (enet cable attached to wifi router or main router) and let the modem cycle up to running.
What you've done is allowed your wifi router to be established as the "MAC" Address for your modem. Modems look for a single MAC address. Once the router has this address, the router will maintain the connection with the modem and the internet, AND will assign MAC addresses to your computers, network printers, network routers etc, while still maintaining your connection to the internet.
4. Turn on all other peripherals, computers and network printers. At this point the order of power up isn't important, because your router will be assigning separate addresses to all the computers, etc on your network.
That's it! The secret's out! Just keep this handy... remember if you have power outage, you'll need to reboot in this order again... Happy Home Networking
on Dec 02, 2009 | Computers & Internet
Wont connect in the net?
Disconnect the router from all computers.
Power off the router. Power on the router. Reconnect the router to all computers. Check the Internet connectivity.
Mar 01, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Last january my d-link WBR-2310 still working fine but now i wanna use it, it wont connect in the net?
Disconnect the router from all computers. Power off the router. Power on the router. Reconnect the router to all computers. Check the Internet connectivity.
Mar 01, 2011 | Computers & Internet
I have a 2wire 1000SW router/modem connected by an ethernet cable to a Hewlett Packard media center PC running Windows Vista. The internet Wifi connectivity problem arose after I visited a best Western...
If you check your router you will find a reset button or a little hole in back insert pin in hole and press for 10 seconds your Moden should have reset now you will have to put in your login and password to access modem
Feb 28, 2017 | 2wire Computers & Internet
Hello wots an router somthing to do withs to internet and how do reinstall it
To understand what a router does, you need to know a little bit about how the Internet works. The Internet, the huge world-wide computer network that we surf the World Wide Web on, uses the TCP/IP networking protocol. Data sent over a TCP/IP network is broken down into chunks called "packets", and in order for these packets to get where they need to go on the Internet, something is needed to route them to their destinations (hence the name router). The many networks that make up the Internet are connected to each other by routers, and the routers determine what packets go where. Routers are level 3 devices on the OSI model, which means that they function at the network layer. The OSI model has 7 levels, and each one represents a function when it comes to data communication between two or more computers on a computer network. To understand what I'm talking about in the next paragraph, you need to know about the OSI model and what layer the router represents.
When the average computer user thinks of a router, they probably think of the kind that you can purchase at your local computer store, as opposed to the big ones that route packets on the Internet. That smaller kind of router allows you to share an Internet connection with multiple computers without having to use a computer that acts as a "gateway". If you have a computer network at home and the center of it is a hub or a switch, you need to use a computer that acts as a gateway ("host" computer), as hubs and switches cannot do what a router does (hubs and switches are two other devices that you can purchase at your local computer store to create a network between two or more computers). A router can "intelligently" route TCP/IP packets to IP addresses (unique identifiers on a TCP/IP network) at layer 3, while a hub is just a dumb layer 1 device that sends out packets to all of the computers attached to it, regardless of who sent them out and who they're intended for. A switch is a layer 2 device that routes Ethernet frames by MAC address; Ethernet is a networking standard that home networks are based on, a frame is the Ethernet equivalent of a TCP/IP packet (chunk of data), and a MAC address is a computer's unique identifier at layer 2 (datalink) on an Ethernet network. Although a switch is "smarter" than a hub, it still can't do what a router does. The functions that a router performs are necessary for communication between the computers on your network and computers on other networks on the Internet at the network layer (TCP/IP). Probably the most important thing that a router does is perform NAT, which stands for Network Address Translation. NAT is a technology that allows computers on a network behind an Internet connection to communicate with computers outside the network; to the rest of the Internet the network is a single IP address (the one your ISP gave you), and NAT allows for incoming and outgoing connections between the computers on the network who have their own "internal" IP addresses and the computers outside the network who see only the ISP-assigned IP address. A "gateway" computer using Internet connection sharing software like the kind that Windows comes with performs the same functions as a hardware router, but there are some disadvantages that come with using that setup, like how all of the computers on the network lose Internet access if the gateway computer is offline. If you want to share an Internet connection between two or more computers in your home, a hardware router is the best thing to get for it.
Dec 04, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i reconnect linksys
Oh man your going to have to help me out a little on this one. Do you mean you had to unhook it and connect directly to the modem and now you want to hook the router back up? If thats the case Unplug all the devices (Pc's modem and router) connect an Ethernet cable from the ethernet port on the back of the modem (not the linksys) to the internet ethernet port on the linksys (usually set a little apart from the rest) then connect all the computers to the routers ethernet ports (usually labeled 1-4) then turn on power to the devices starting with the modem, wait for it to completely boot up all the lights like they're supossed to look. Then turn on the router and wait for that to finish booting up then all of the computers. If you have wireless devices that will take a little more help.
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Router won't connect to the internet.
bypass first the router and check if there is an internet connection. It might be no internet service at that moment.
Feb 26, 2009 | Linksys WRT160N Wireless Router
No internet connection with laptop computers in home
Good day!
If your Desktop computer is hardwired to the router and your laptop computers can't connect wirelessly, it could be your wireless computers are not synchronized with your router by not having the same settings as the router.
You can use the desktop machine to access your router web interface (setup page) to check the wireless settings such as SSID (Network Name-> Name of your wireless signal shown on your laptop computers), channel and security (wether it is WEP or WPA encryption)
The channel and network name will be automatically detected by the wireless computers. If you have an encryption/security on the router, you need to type the password on the wireless computers for them to authenticate.
Try these and post back if there's any progress
Aug 03, 2008 | NetGear : WGT624 108 Mbps Wireless...
D-Link AirPlus DI-524 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
