Question about Philips Audio Players & Recorders
Philips wac700 freezes at startup saying booting up please wait
  • Philips Master
  • 19,396 Answers
Try first unplugging the system from power for ten minutes.
That probably will not work.
Try holding down the stop and source button at the same time, the system should start backup recovery.
If backup recovery does not work, then the hard disk may be faulty and will need replacement.
Posted on Sep 05, 2009
Can't do a system restore
Please contact acer and ask for operating system disk.
Jul 07, 2013 | Acer Aspire Computers & Internet
Phillips wac700 says booting up has not been used for a while
Hello
Just unplug the device from AC mains socket and replug it after 3 minutes and see whether it helps you. If not, a firware upgrade will be necessary. The supplied PC installer CD contains Media Manager [DMM] software. it will help you to upgrade for WAC700 center. For details see DMMs' help file. Refer to the manual CONNECT YOUR PC to learn how to install the software. OK.
Jan 16, 2012 | Philips WACS700 Shelf System
Mp3 player not starting.
reset is the best way from uu can do.... may helppp
Jul 29, 2009 | Philips SA3125\02 MP3 Player
Streamiun Wac700 CENTER says can't connect to center...help!
put units side by side and switch them both off. Plug in main unit, and using menu resort factory settings, then when it reboots, select language, and leave it there. Then connect the smaller unit and do the same thing (restore settings), they should then find each other.
Apr 27, 2009 | Philips WACS700 Shelf System
ACER 360 VA381M
Tap F5 as pc is booting to go into safe mode. Once there type msconfig in the run box and wait for window. Under the startup :tab: uncheck everything that is there unless it says "SYSTEM" next to it. Then restart pc.
Jan 05, 2009 | Acer ASE360 MT A3500+ 1GB- 200GB DVDRW...
Boot error...please wait
1 Hold down the power button for 15 seconds.
2 plug into usb on pc.
3 Update the firmware
http://www.rcaaudiovideo.com/categories.aspx?product=317&post=4
Good luck. Worked great on mine.
Dec 30, 2008 | RCA M4204 MP3 Player
WAC700 Wireless music center
This can be caused by either corrupt firmware, or bad connection between the front panel and main unit.
The firmware can be restored as follows:
Unpluck the unit from the mains.
Press and hold [STOP] & [SOURCE]
Plug unit into mains.
Continue to hold the two buttons until the recovery message appears on screen.
If the progress bar doesn't move at all within 5 minutes, then this is not the problem.
______________________________________________________
This problem can also be caused by the ribbon cable connection between the front panel and the main unit. Sometimes the problem can be cured by disconnecting both ends of the cable.
The firmware should still be ok in this case.
There are multiple processors in the WACS700 unit, and the problem occurs when they can't talk to each other.
An authorised service agent should be able to sort the problem with a replacement cable.
Mar 15, 2008 | Philips WACS700 Shelf System
WACS700/05 Wireless Music Centre will not Boot up
tried to hold source and stop got message firmware damaged retriving copy from backup. power turn off, hold down source only power on comes up booting up please wait but in the lite up mode, 30 seconds later everything back on
Aug 20, 2007 | Philips WACS700 Shelf System
63 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
