Question about Garden
Starts fine runs about 10-15 minutes then shuts down till it cools off then cycle begins again
  • 1894 Answers
SOURCE: Constant cycling
do you use a inverter.. or any protection circuit>
if so remove it and connect it directly
Posted on Apr 05, 2008
  • 4 Answers
SOURCE: shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Posted on Sep 02, 2008
  • 10865 Answers
SOURCE: craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
Dump the fuel in the tank, get new gas and new oil and start over. Get a carbeurator cleaner additive for the gas as your carb. is dirty resulting in the sporatic operation.
A spray carb. cleaner that you squirt into the air intake by removing the air filter will also work for you. In fact, when you are getting the carb. cleaner get a new air cleaner and a new spark plug. get back and let me know how u make out.
Posted on May 20, 2009
  • 69 Answers
SOURCE: 1986 Yamaha Radian stops running after 20 minutes
Sounds to me like it could be a few things... pretty interesting that it runs and shuts down...sits for a little while then fires back up. Could be something as simple as a bad ground.. maybe it needs cleaned.. if the ground is making very little contact.. the bike would run bad, and because its direct current it has to flow. The metal in the motor frame etc will hold so much DC current.. but *** soon as it load up the bike would stop sparking. Let it sit for a while, DC trickles into the battery through the slight contact, bike fires back up. OR could be bad venting of your fuel tank, or a partial clog at the pet ****.. the first is pretty easy to check, open your fuel cap and start the bike..if it does the same thing then its not a vent problem. One thing that does happen on the Radian, is the reserve fuel screen inside the tank comes loose, and then everything inside the that has built up over the years either partially clogs the pet ****, or the hose, or both. Take the tank off, pull the pet **** off..if it still has two intact tubes with good screens..you probably don't have any junk in your line..but I would pull the line off and blow through it any way... it could be some type of blockage, when the bike sets the fuel seep through, but when it runs it eventually creates a vaccuum that stops the fuel flow. Those are my two first thoughts... good luck!!
Posted on Jun 07, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Posted on Jul 27, 2009
My Kawasaki twin engine model FD 590 on my lawn tractor sputters, looses power and shuts down after about 15 min of running. Will star after it cool down. Cause please??
Immediately check for spark after it dies. A failing ignition module will quit after it gets hot (about 10 minutes) then work again after it cools. Other causes could be a blocked tank vent; try to run till it starts to act up and loosen the fuel cap. See if it starts to run right again or if it does die it starts right back up. A sticking shut-off solenoid, sticking float needle or partially clogged fuel filter can also cause these symptoms. They let some fuel in but not enough and eventually the motor starves for fuel. then slowly the fuel fills back into the bowl and it will run again for awhile till it runs out of gas again.
Sep 01, 2014 | Garden
My 95 ford f150 runs great till it warms up it seems then the fuel pump looses power n shuts down wait few mins kicks back on runs fine till few min later
Sounds like your ignition module it is common on fords to do this when its cool it will start and run fine but once it heats up the truck dies until you let it cool down again and then your up and running till it heats up again. Some modules are mounted on the fender others are mounted with the distributor have it checked and let me know how it went.
Aug 26, 2014 | Cars & Trucks
I have a kenmore dry that seems to hum very load once it heats up. If you turn it off and rest for 30 minutes it will sound fine again until it is 15 minutes into the cycle. What would be the likely...
Hello Bill,
Sorry to be the bearer of bad news,but what your describing sounds exactly what a bad motor will do...run whiles is realitivly cool,cut off when hot the restart after a cool down period and run for a while till hot again.
GENE
Sep 12, 2011 | Kenmore 84072 Electric Dryer
Jul 27, 2009 | Dryers
Runs fine for approx 15 mins,then stalls out and wont start again
sounds like coil problem, coils will start cold then get hot and stop. when coil cools will crank up and run till it gets hot, try to replace the ignition coil,dont think it would be a crank sensor, try a coil,thanks robert b.
Jun 19, 2009 | 1993 Jeep Cherokee Country
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
