Question about RTO Mini Quads
Yamaha 80cc bager with weak spark wont run
Changed spark plug. wont fire at all, gets plenty of gas is there any common problem i shoud look for. thanks!, Samantha
    Problem Solver:
  • 10 Answers
Samantha,
Electrical problems can be either, coil, (most common) stator, magneto, or timing. Make sure the coil is grounded to the frame of the quad and not against a painted part. It should be in contact with raw metal. The stator or magneto could be tested at a dealer. Good luck.
Posted on Apr 06, 2010
I have a 2002 pt cruiser it is getting gas and fire but the fire is weak
Weak spark could be bad coil(s) or ignition module. Even a bad groud strap can cause this, but most common is module.
May 04, 2015 | 2002 Chrysler PT Cruiser
Motor turns when spark plug is out, starter works, gas good, but has plenty of spark, when plug is added it stalls. Why?
If by 'stalls' you mean it wont turn over with the spark plug in, it is common in B&S engines for the valves to go out of adjustment. When this happens it can make it very hard for the engine to turn over and can make it hard for it to crank without assistance. A valve adjustment may fix this. it may also be a weak battery that isn't strong enough, or a bad solenoid that isn't letting enough juice through, or weak connections/bad battery wires.
Aug 01, 2012 | Toro Garden
455 wont run
Make sure the muffler has not become plugged. Check the flywheel key as it may have sheared off for some reason causing the timing to be off, yet still generate sparks. Are the sparks blue and snappy? If not, check the ignition module gap to the flywheel magnets--use a thin business card for a gauge. A wide gap can cause weak spark. Hope this gets you running again!
Apr 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Continualy turning over and wont fire up, Im getting a spark off all 4 plugs carbs appear to be clean just wont fre up
squirt a bit of aerostart in the air cleaner, if that makes it run its a carby fuel problem, if that doesnt make it fire, do compression test, check valve clearance , valve timing
Apr 06, 2010 | 1981 Suzuki GS 750 L
Yamaha xt 125r wont start up
hello, check and see if plug is firing a blue color, if not you may need a stator-pickup coil, i have a 2000 warrior, it is firing, orange and white color, stator neede to be replaced, pickup coil was going out, also check ign coil, these have a problem with getting weak after a while. most likely it is your stator pickup coil, no blue fire from plug, no running the motor. my stator pickup coil was going out. no blue fire from plug, i was told by a yamaha mechanic, no blue fire from plug it will not run, has to be blue, not orange or white looking fire.make sure carb is clean and all jets inside are clean, and air passage ways
Feb 22, 2010 | 2005 Yamaha XT 125 R
Got given a old yz 80 changed piston and rings its fireing but wont start?
I'll start with the obvious.... have you tried removing the plug, putting a little gas in the cylinder, putting the plug in and wire back on and then kicking it over? If it starts, runs for a couple seconds and dies (burns off the gas you just put in there), it's a fuel or fuel delivery problem. Has the carb been cleaned, the needle and seat checked, the float height checked, air passages cleaned out, etc.? These carbs are famous for getting gummed up after sitting a while. (I have 4 dirtbikes and clean the carbs every spring before firing them up for the first time). Is the oil to fuel mix ratio correct? Too much oil will cause this as well. If it doesn't start with gas poured in the cylinder as mentioned above, check to see how strong of a spark you have and if the plug is gapped correctly. The spark should be bright blue. Hopefully you know how to check this, but if not, take the plug out, put the plug wire back on the plug and lay the electrode end of the plug (spark end) up against the cylinder head with the end of the plug touching metal and kick the kick starter over. You should see a bright blue spark. If it's a weak spark (not bright blue) it's an electrical problem such as a faulty coil. (WARNING: DO NOT HOLD THE PLUG IN PLACE WITH YOUR BARE HAND when kicking it over. You will get zapped good if the coil/spark are ok.) Try these troubleshooting tips and then let us know the result. We'll go from there.
Oct 29, 2009 | 2003 Yamaha YZ 125
1997 yz 125 wont start, please help
2 stroke bike are very dependent on compression. and being a bike that is 12 years old my best educated guess is that the top end needs to be rebuilt. i usually have to have the top end done on my honda about every three years.
Jan 12, 2009 | 2003 Yamaha YZ 125
RTO Mini Quads Logo
620 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
