Question about Toshiba Tecra® M8-ST3093 PC Notebook
I have a Toshiba Tecra M8 and the touchpad stopped working. I can still use a USB mouse, but i've tried the FN F9 key to make sure that the touchpad is enabled but it still isn't working. Are there drivers i should update?
    President:
  • 1,015 Answers
Check in the device manager and see if the touchpad is listed under pointing devices.If it is not there try add hardware and see if it detects the hardware. If it is there check to see if it says device is working properly. Sometimes touchpads require software to operate properly so check and see if software was uninstalled. You can also download the drivers/software from Toshiba, try removing the touchpad in the device manager and then re-booting the computer. When windows re-boots it should start installing new hardware found. Use the driver/software you downloaded from Toshiba. If none of these work your touchpad may be bad.
Posted on Sep 05, 2009
Mouse touch pad not working
'F9' keys has a mouse, no mouse looking symbol. sometimes you use the 'Fn' key in conjunction with 'F9' key, sometimes not. Give it a try by itself and use it. If not hold the Fn key and hit F9 and try again.
Jan 08, 2014 | Toshiba Satellite A355-S6925 Notebook
It stopped working what to do to start it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
Jun 29, 2011 | Microwave Ovens
My onborad mouse on my toshiba Tecra A3 pta3u14004 is not working how can I fix it
You can enable or disable your onboard mouse with Fn+F9
TouchPad Enable/Disable ( Fn+F9 ).
Regards
Jun 03, 2011 | Computers & Internet
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
How do you unlock the mouse touch pad?
5. Go to http://support.toshiba.com there click on Downloads.. select your computer.. Product=Portable, Family=Satellite, Model=M35X-S149.. then click on "GO" button on the right.. Again in the next page that comes up click on "Downloads"..
06-15-2004 Driver
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else.
Thanks for using fixya...
Sep 15, 2009 | HP Compaq nc6000 Notebook
My mouse button is lock how do i unlock it
5.Install Drivers
06-15-2004 Driver
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else. Thanks, CF
Jun 25, 2009 | Computers & Internet
Hi! My touchpad mouse has stopped working in my toshiba satellite L305-S5875 notebook please help
While holding the "FN" key, press the "F9" key and that should re enable your touchpad.
Apr 19, 2009 | Toshiba Satellite L305D-S5874 Laptop
How do I disable my touchpad on my Toshiba Portege 700?
Toshiba usually set the keys Fn+F9 as the touchpad enable/disable - the touchpad software has to be running in the taskbar to allow this however.
hope this helps 8)
Dec 07, 2008 | Toshiba Portege 3500 Tablet PC
I need to disable touch pad and use a usb mouse
Disabling touchpad for toshiba laptop is easy. Press FN and F9 simultaneously. Touchpad will stop working.
Sep 26, 2008 | Toshiba Satellite Pro 4600 Notebook
Touchpad is not working - TOSHIBA Satellite A135-2386
Hey there... :D
Could you try the Fn+F9 Key to Disable/Enable your touchpad mouse?
Because just now i've experiencing the same problem as you guys... and turns out I can make my touchpad working just by pressing the Fn+F9 key.
Note: if your Fn key is not working try installing Toshiba utilities for A135 called FlashCard, run the program and there will be a dropdown menu at the upperside of your screen...
then click on F9 >> and choose Enable.... Thats It... :)
I hope it also solved your problem... :D
Mar 19, 2008 | Toshiba Satellite A135 Notebook
Toshiba Tecra® M8-ST3093 PC Notebook Logo
179 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
