Question about T-Mobile Sidekick ID Cellular Phone
MY SIDEKICK IS DELETING INFO
Every time I take my battery out while the phone is on, the sidekick deletes my contacts, notes, and stuff on the calender. This also happens durind road trips when I turn my phone off. Whay s this and what can i do to make it stop? Do I need to get a new phone?
How do you unlock a sidekick without deleting anything?
Hi. I can help. Your unlock code depends on your phone's IMEI or serial number. You can call your service provider and sometimes they will give you the code for free.
Nov 11, 2009 | Sharp Holster Belt Clip for Sidekick LX...
Sidekick lx '07
SAMSUNG PRODUCT
Samsung S5600v Blade ..........$300
Samsung I8000 Omnia II ........$275
Samsung E1390 .....................$280
Samsung E1160 .....................$275
Samsung E1130B ...................$285
Samsung S8000 Jet ................$230
Samsung i8910 Omnia HD ......$210
Samsung E1360.....................$250
Samsung E1210.....................$240
Samsung i8510 INNOV8...........$230
Samsung i900 Omnia..............$240
Samsung i7110.......................$220
Samsung Armani.................... $220
Samsung M8800 PIXON............$240
Samsung J800 Luxe.................$235
Samsung L700........................$230
Samsung S9502 DUOS.............$240
SIDEKICKS PRODUCT
Sidekick LX 2009 .......... $170
Sidekick 2008 ............. $150
Sidekick LX ................. $110
Juicy Couture Sidekick II ........ $120
Mister Cartoon Sidekick .......... $130
Juicy couture Sidekick III ........ $130
Sidekick D - Wade ................. $130
Contact: Mr. Randy Barnett
Email: isell.seitz@gmail.com
Email: isellfast198@yahoo.com
Chat with me on MSN: i-sell@hotmail.com
Nov 09, 2009 | T-Mobile Sidekick
My phone deleted all of my contacts, pictures, emails, ect.
Are your pictures, contacts, etc. on the desktop interface still? Go check your desktop interface. If it is, pull the battery let it sit for a moment and place it back in. Turn on the Sidekick and Danger's servers should put your stuff back on your phone.
Sidekick ID does not have the SD card slot, so it can't be an issue with your SD card. This was the first thing that came to mind.
Hope this helps,
Bill
Oct 04, 2009 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 problems
hi you have to call tmobile and let them know that you have the sidekick 3 and you want the sidekick plan they will set you up on the plan
Jan 03, 2009 | T-Mobile Sidekick® 3 Cellular Phone
When my sidekick 3 dies i have to reset the time
Do you have the Sidekick data plan from t-mobile? If not, the data is not being stored on the Danger servers and will delete when you phone dies. You also need that for the web, chat, and email.
Sorry
Jan 02, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Ayy
Is the orange light coming on but you have no power? If so, then it is probably not charging. The sidekick 3 charging port is notorious for going bad. The little contacts that send power to battery come loose.
Find a friend that has a sidekick 3 or sidekick ID and try out their battery. If it powers up, it is your charging port.
The easiest thing to do is to get a charging cradle that has a spare battery charging slot. They run about 25 dollars off off ebay and allows you to charge the battery seperate from the phone. A spare battery is good too as it allows you to have one charging at all times.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Sidekick Spare Batteries
Jun 07, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick deleted all contacts
When the sidekick does a hard reset, it drops all the data until it resyncs with the data servers. When the battery is loose, this is what happens
It sounds like the battery is loose. What you need to do is power the sidekick off. Then firmly reset the battery and place a folded up piece of paper between the battery and the battery cover. This will keep it firmly in place.
May 30, 2008 | T-Mobile Sidekick ID Cellular Phone
this happens when you don't charge it and it dies.
May 08, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick
Is it a sidekick 3? If so, is it under warranty? If yes, call t-mobile. The sidekick 3 is known to have an issue with charging ports going bad.
If not under waranty, it will run around 100 dollars to fix.
The other option is to get an external charging cradle and a spare battery. Make sure the cradel has a spare battery chargin slot. This will allow you to allows keep one battery charging and one in the phone. Both items will run about 40 dollars on ebay.
Check out the link below for some more info.
http://shop.sidekickskin.net/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Dec 12, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Something terribly wrong with my sidekick
The memory is just a temporary storage of your data, still depending on your battery life.
Rate me solved please.
Nov 21, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick ID Cellular Phone Logo
74 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
