Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Motor does not always start and only hums. Manual push ok.
Working on my son's Master Cool and the cooler works only with manual help of turning the carriage... Once going it works fine... However, that is not the way I want it to work... Have heard mention of a starter being bad on the motor but on inspection, have found a large capacitor... Is that the starting mechanism I need to change? The motor pulley is adjustable, so I have made it much smaller... It works the first time, but after testing it again, when the motor is warm, I need to help it manually again...
I sure would like some help here.... I am usually the 'go to' guy for fixing things, but right now I am stuck... Any help out there?
RADelgado@verizon.net
Rob
  • 128 Answers
There are two main reason
1- start capacitor
2- may you tight the belt too much.
Posted on Sep 05, 2009
Testimonial: "You guys are really good... This is the second 'fix' I have received that made sense to me... and your response timing is terrific... BRAVO!! "
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Husky air compressor motor hums won't start
In a safe manor, when the motor is humming, give one of the pulleys a push to help get the motor started. If the motor runs OK with the help push, the start capacitor is bad. If not the next thing to check is the tank check valve.
Nov 23, 2012 | Air Tools & Compressors
My fuel pump is not starting no gas gets to he motor
Fuel not starting.turn the key on but dont start it do you hear a humming noise (there loud on Ford) yes the fuel pump works No humming noise then the pump is not working. One more thing do you have the owner manual yes okay we need to find the fuel shut off valve more likely it will be in the trunk are open the trunk did you find it it should be to the left and it will say fuel shut off push the button go back and turn the ignition on does the humming noise start?
Apr 22, 2011 | 1999 Ford Taurus
GE dryer model DDE8200GALAD was working fine. After removing a load and trying to dry another, after inserting the load and shutting the door when you turn the timer to start it before pushing the start...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 23, 2011 | GE Dryers
Please HELP.... I have a Whirlpool Quiet Dry 1 Dryer, it's about three years old and just stopped working. I have had no problems with heating. When I turn the dial to a setting I hear a humming sound but...
ok ok ok,,,keep cool? try checking the drive motor it may have burn out or jamed up so wont be turning but it may be causing the humming sound you here,
Nov 28, 2010 | Dryers
I need an owners manual for my master cool. Can you help. Also, what size motor pulley is required for a 3/4 horse motor and a 1 horse motor?
Hello You need the SHAFT diamater size on the motor.And they have an ADJUSTABLE pulley to set.Bring the old one if possible.
Sep 15, 2010 | Mastercool 67680 Evaporative Cooler Air...
MasterCool 2 took a dive
Did you look at the unit. Maybe the belt broke or came off. Do you have voltage to motor. Need to follow the power to know where the problem is. Verify the breakers is good and there is power to the swamp cooler.
A frozen motor would not stop the pump from working. But the motor could have blown the breaker. Start by checking to make sure the power is good to the unit.
Aug 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
Water Leaking from pump
How COOL is this. At first I thought this was some crazy graphics card cooler that I've never heard of!
Well here is the manual anyway.
http://www.air-n-water.com/manuals/MMB12-4Manual.pdf
And here is a Parts Catalog from a company in Arizona I found at random. This one takes a little longer to load just give it time.
http://www.dialmfg.com/Technical%20Assistance/TECHINICAL%20PDF%20DOCUMENTS/2008%20Cooler%20Parts%20Catalog-all.pdf
Jun 10, 2009 | Cooler Master Coolermaster CoolViva Video...
GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Mar 28, 2007 | GE Profile DPSB619ED Electric Dryer
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
478 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
