Question about Fedders A3X05F2C Air Conditioner
Can you install an portable window fedders a3x05f2c sideway?
  • 20 Answers
You sure can, but it will not work for very long. The compressor is designed to work the way the Mfr. has made the A/C and if you tilt it up, then the compressor will "flood" out and come to a screeching halt. The kind of screeching halt that makes you go buy another A/C. Do your wallet a favor and set the unit correctly.
Posted on Sep 06, 2009
I have a Fedders portable roll around unit that is leaking water all over floor from underneath the unit. it does not look like the drain line is clogged. used to drain through hose but does not anymore....
Hello, Take a clothes hanger wire in the hole a little ways and see if it is stopped up. If that doesn't work get a can of air and blow in the hole.
Jun 05, 2014 | Fedders Heating & Cooling
Where is fedders 5000 btu drain plug
If you have a window unit or thru the wall unit, Drain Hole is located under the drip pan at near the rear of the unit. It may be difficult to find if it is clogged. As the clog will blend in wit the hole.
Hope this helps you locate it. Thanks for choosing FixYa.
Aug 24, 2011 | Fedders A3X05F2C Air Conditioner
Fedders AEP09D2BCOM Portable Air Conditioner. The unit shut off and the buttom with a triangel and ! is flashing
That flashing triangle indicates that the water collection tank is full and must be drained.
Aug 01, 2011 | Fedders AEP09D2BCOM Portable Air...
I can't find the window adapter and hose for the portable Fedder #A6P09S2b.Any suggestions?
Cut a piece of plywood to fit your window opening, install a flex connector ductboard%20collar.jpglike the one shown here, and use flexible duct to connect to your unit and the connector you attached to the plywood. flex-duct.gif
Mar 19, 2010 | Fedders SFPEB08F2A Air Conditioner
Need a window install kit. The original got
With a glass cutter, you could cut the glass to the correct size and using some angle aluminium strip and some silicone, then seal between the unit housing and glass. Hope this helps
Nov 04, 2009 | Fedders X Chassis A6X05F2B Air Conditioner
Air conditioner fedder 6000 btu
No. The oil will not return properly to the compressor.
Jul 27, 2008 | Fedders A&B Chassis A1A07W2B Air...
Heating & Cooling Logo
79 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
