Question about Craftsman 25cc Gas Line Trimmer
Fuel lines inside of tank fell off
Would not start seemed like it was not getting any gas so I looked in the tank and the little barbed fitting was not hooked cause the line was ripped off. Looking into the tank neither line was hooked to anything and when I drained the gas 2 line fell out and on the one there is a filter. I need to buy some new line cause it seemed brittle. I was looking for some drawing of the tank so I could see how the lines hooked to where as my owners manual does not show anything for the how the lines are hooked up to make it run.
    President:
  • 1,776 Answers
This is the typical fuel line routingfuel lines inside of tank fell off - 2.gif on many models: One line ( the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the lower port on the carburator. The second line goes from the fuel tank to the bottom fitting on the primer bulb. The third section goes from the top port on the primer bulb to the top port on the carburator. Hope this helps and best wishes.
Posted on Sep 05, 2009
Where does the fuel line with filter from fuel tank goes on carb cs310? I have it on the large port at top of carb.
looking st the throttle end of this crb it looks like the fuel lne goes to the barbed fitting on the carb. and it looks like that is the top fitting? being you don't say what machine it is on, they use this one on a few machines.
https://www.echo-usa.com/getattachment/96a50388-9f60-4df2-9e1c-d178671a6a7b/CS310es1112_100413.pdf
Nov 02, 2017 | Garden
Gas leaking from my tank switch
Use compression barb fittings on the pressure side with fuel injection line NOT REGULAR FUEL HOSE THE REGULAR HOSE WONT HOLD UP TO THE PRESSURE. The return line can be regular fuel line because of the low pressure.
Feb 02, 2014 | 1987 Ford F 150
I have a poulan p3314 chainsaw. It has been sitting up for a while. When I started it, I could not get it to run beyond an idle. Every time I squeezed the gas, it quit. Finally, it quit and refused to...
The ful line actualy disloved and the problem is inside the carburtator there is a valve that lets fuel into the fuel bowl and also shuts it off when its full the floats control it so its always opening and closeing that is stuck closed from the melted fuel line you need to clean the entire carburator out the neddle valve may have a rubber tip at the seal point so take care not to damage it ware it makes the seal but its not hard to do anyone with some common sence and a little mechanical abilitly can do them selves
Nov 23, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
How far does the return gas line on a ryobi string trimmer extend
There is supposed to be a barb fitting with a flange on top of it that is on the end of the hose, inside the tank. If you do not have that barb in place the gas will start to leak out of the tank in a short time. Barb fitting is designed to have hose stick up about 3/16" into the tank when the hose is properly installed. You put the new hose on the fitting, thread the other end of the hose through the fill opening of the tank and out the hole in the bottom. Pull hose through until barb comes through the hole in the tank and the flange is flush with the inside bottom of the tank. There is supposed to be a plastic ring that fits over the bulge in the hose/barb at the bottom of the tank on the outside. Serves as a retainer for the fitting.
May 19, 2009 | Ryobi Garden
Need to know how fuel system and fuel lines are installed fuel lines dryrotted cant determine where to hook each line can i see a diagram
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outside of tank and push fittings into tank, then shake out of the fill opening. More details on proper installation follows.
If yours is like all the Ryobi units that I have seen you just need a piece about 12" long of 1/8 ID fuel line. You can usually order that from parts suppliers or get it at some lawn and garden repairs shops. Hardware stores will not likely have it. There is a fitting with a hose barb on it that fits through the tank. On the outside of the tank on the bottom there will be a round plastic ring, assuming the fitting is still in place and just the hose split at the fitting. Use a knife or thin blade of some type to pry off ring. It is actually around the hose that is over the barb. Keep ring, you will need again. Now push fitting up into the tank. You may have to trim off the hose that is outside the tank on the barb to get it to go into the tank. Shake tank around and get fitting out of tank. You will see there is a piece of hose on it yet. Remove that piece of hose. Now take the new hose and slide it onto the barb. It must go all the way to the top of the barb fitting so that the hose actually goes into the tank through the hole drilled in the tank. The OD of the hose acts as the seal to keep gas from leaking out of the tank. You may need to put some oil of some type (vegetable oil works well) on the barb and inside of hose to help slip it on and use some pliers with smooth or rounded jaws ( no serrations, will damage hose) to get hose on. Thread other end of hose into the fill hole of the tank and out the hole in the bottom of the tank. Hint: Straighten out paper clip or use small wire inserted into the hole from the bottom of the tank up towards the fill opening. Slip tube over that and use the wire to guid the tube directly to the opening. Pull hose through the tank. When fitting with barb and hose over it reached the hole in the tank it will resist being pulled through. Carefully pull firmly on hose to stretch it so the hose/fitting "bulge" pulls into the hole in the tank. Look into tank and see when top flange of fitting is tight against the bottom inside of tank. You should see bottom of barb outside of the tank with the hose on it. Once in place put the plastic retainer ring back over hose and push up to bottom of tank. It should fit snuggly when you get to the "bulge" area. Cut hose length as needed to fit onto straight tube fitting on primer bulb. Should be good to go. You may find that the other hoses are getting bad also and may want to change them at the same time, as they will probably be ready to crack also. You can reuse filter from tank if it is not plugged, just add a new hose as described previously. Otherwise you can order a new filter with the line already on it. That line goes directly to the carb inlet barb. That barb is also hard to push hose on. Third line is from the return side of the carb to the suction side of the primer bulb. That is just a straight piece of 1/8" ID hose and pushes onto straight tube fittings, very easy to get hose on compared to barb fittings.
May 18, 2009 | Ryobi Garden
Replaced new gas line, new primer bulb, new gasoline. need to find out if gas line routing is correct / trimmer will start, but very hard to start, clean air filter. carb never been adjusted since new.
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
Have you checked the spark plug?
May 12, 2009 | Garden
Ryobi 700r 31cc 15" Trimmer
Just break off plastic caps to access the low and high speed jets. They are there because of government regulations to prevent users from adjusting carb in the field. They serve no other purpose.
Supply line with filter is suppose to be one piece from the tank to the carb. If it has a barb coupling in the middle then someone must have tried to patch the line at some point. You can get a replacement line and filter as part #682039 by searching online or ebay. Or you can just order line and reuse filter if it is not plugged. Required line is 3/32 ID x 3/16" OD. Both dimensions are critical. To replace line you have to take retaining ring off the bottom of the fitting on the tank (use a knife or scraper to pry it off the bulge in the hose) and push the filter fitting into the tank. Remove from tank through the fill opening. Remove piece of hose that is still on the barb. Push on new section of hose all the way to the top of the barb and right up to the filter. Put other end of hose through tank fill opening and through hole in bottom of tank. Use a piece of wire or a straightened paper clip to guide it to the hole. Pull hose through until the bulge gets to the opening. Pull hose firmly, but carefully so the hose stretches enough to allow the bulge to go into the hole in the bottom of the tank. Stop when the bottom edge of the filter is about 1/8" from the inside bottom of the tank. You should see enough of the barb end sticking through the tank for the retaining ring to be replaced on the outside bottom of the tank. If not enough exposed, pull hose through a little more. Thread line to carb input and insert. Inlet fitting will have barbs or a bulge on it. The return fitting on the carb is a straight tube with no barbs. The line from that fitting (3/32 x 3/16 also, as all lines are) goes to the top (suction side) of the primer. The other side of the primer has a line that returns to the other opening in the tank.
The return to the tank must have a fitting similar to the filter fitting, but without the filter. It is a barbed fitting with a flange ring on the end that is inside the tank and it has the retaining ring on the outside just line the supply side line. It sounds like you are missing that fitting, because you are describing the hose just being pushed up into the tank. Without that barbed fitting in place the tank will leak gas. The bulge in the line caused by the line fitting over the barbs is what seals the opening. You can order a return line kit 147290 from MTD parts that will have the line, the barb fitting and the retainer ring. In a pinch you could get use an 1/8" hose barb from a hardware store and just arefully pull it through the opening so that the bulge in the barb/hose combination is sealing the tank both inside and out. You can get by without the retaining ring. Otherwise look for a junk IDC/Ryan/Ryobi trimmer to scavange parts off of.
Sounds like you may still have a carb problem to deal with. Did you remove the needle valve to make sure it is not stuck or inlet plugged or restricted? Fuel screen clean? May need a diaphragm and gasket set. Good luck.
Apr 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 768r fuel line
Mar 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Return fuel nipple is broke from finger pump
The part previously recommended is not the correct part if it is the return line that is bad. Return line does not use the filter. If yours is like all the Ryobi units that I have seen you just need a piece (about 3-4" needed, but buy extra.) of 1/8 ID fuel line. You can usually order that from parts suppliers. Hardware stores will not have it. There is a fitting with a hose barb on it that fits through the tank. On the outside of the tank on the bottom there will be a round plastic ring, assuming the fitting is still in place and just the hose split at the fitting. Use a knife or thin blade of some type to pry off ring. It is actually around the hose that is over the barb. Keep ring, you will need again. Now push fitting up into the tank. You may have to trim off the hose that is outside the tank on the barb to get it to go into the tank. Shake tank around and get fitting out of tank. You will see there is a piece of hose on it yet. Remove that piece of hose. Now take the new hose and slide it onto the barb. It must go all the way to the top of the barb fitting so that the hose actually goes into the tank through the hole drilled in the tank. The OD of the hose acts as the seal to keep gas from leaking out of the tank. You may need to put some oil of some type (vegtable oil works well) on the barb and inside of hose to help slip it on and use some pliers with smooth or rounded jaws ( no serrations, will damage hose) to get hose on. Thread other end of hose into the fill hole of the tank and out the hole in the bottom of the tank. Hint: Straighten out paper clip or use small wire inserted into the hole from the bottom of the tank up towards the fill opening. Slip tube over that and use the wire to guid the tube directly to the opening. Pull hose through the tank. When fitting with barb and hose over it reached the hole in the tank it will resist being pulled through. Carefully pull firmly on hose to strech it so the hose/fitting "bulge" pulls into the hole in the tank. Look into tank and see when top flange of fitting is tight agains the bottom inside of tank. You should see bottom of barb outside of the tank with the hose on it. Once in place put the plastic retainer ring back over hose and push up to bottom of tank. It should fit snuggly when you get to the "bulge" area. Cut hose length as needed to fit onto straight tube fitting on primer bulb. Should be good to go. You may find that the other hoses are getting bad also and may want to change them at the same time, as they will probably be ready to crack also. You can reuse filter from tank if it is not plugged, just add a new hose as described previously. Otherwise you can order a new filter with the line already on it. That is the part that was recommended to you earlier. That line goes directly to the carb inlet barb. That barb is also hard to push hose on. Third line is from the return side of the carb to the suction side of the primer bulb. That is just a straight piece of 1/8" ID hose and pushes onto straight tube fittings, very easy to get hose on compared to barb fittings.
Hope this helps. Contact me if you have any questions.
Mar 04, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 700r gas trimmer, replace old fuel lines
To leemineres, if hoses are on right and unit still stalls after starting initially you probably need to disassemble carb and clean out using spray carb cleaner. May be sticky needle valve, or partially plugged port or jet.Could also be hole in diaphragm. Gasket and diaphragm kit would be good to add when you take apart, even if diaphragm does not have a hole.
Jan 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Craftsman 25cc Gas Line Trimmer Logo
251 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
