Question about Dryers
Dryer will not start, worked all day, changed loads, and would no longer start
  • 6,784 Answers
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Posted on Sep 05, 2009
Samsung Steam Dryer has power but only displays a flashing smiling person. The dial will not turn and will not start cycle??
Maybe you press lock button, simply unlock it again try this one
? What is the "Child Lock" function?
• If you press the "Child Lock" button (Spin+Option button) longer than 2 sec during operation, this
function is selected.
• If once this function is selected, no change can be done until the end of laundry.
• Press the "Child Lock" button (Spin+Option button) longer than 2 sec to cancel the function
Jan 19, 2015 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
Changing belt maytag legacy dryer sde515dayw model
Have someone else look at the machine, I'm not sure about the last guy. Do smaller loads to ease up on the machine. It will last a lot longer doing more, but smaller loads.
Nov 29, 2013 | Dryers
My 5 year old Whirlpool dryer just didn't start one day.Instead of dealing with repair,we got a used 4 year old Maytag dryer.It dried the first load,then when I pushed the start button it made a weird...
It is the motor winding shorted out which caused the smell. If you still have your old dryer the safty thermal located on the exhaust housing is blown. White plastic with 2 wires going to it. Very inexpensive repair. Hope this helps.
Feb 13, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
After sitting idle for several days, dryer makes a noise at beginning of the cycle when drum stops and starts. Noise no longer occurs after second load dries.
Not sure if your problem has been corrected yet, but the biggest most important task that must be addressed constantly with these machines is lint build up. So I would check your lint trap (change it before or after each load), check your heat exchanger/air inlet on the lower right hand corner of your machine, and then your condensation hose - to make sure that this is clear of blockage. Also, your machine should be in a vented, open area where it gets lots of air. Adequate ventilation is another important feature that affects these machines. So basically, I'd give it a little tune-up/clean-up and see how it runs. Hopefully, this has already worked for you. Good Luck!
Jan 16, 2010 | Bosch Axxis WTL 5410 Electric Dryer
It won't start - worked fine all day and then
check the drum belt, some dryers have a "kill" switch when the belt breaks the dryers will do nothing.
Oct 11, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer is acting weird
your dryer motor is no longer strong enough to turn the drum,how old is the dryer?mike
Apr 04, 2009 | Kenmore Dryers
Heavy loads (e.g., jeans, etc) is tripping the circuit breaker
WOW, 10yrs was a good investment of your money. Anyhow large amp loads may be contributed to the motor or fatigued heating elements. Also the breaker can wear out if its ran loaded for extended periods. Here are a few things you can try. Check to ensure that the barrel sleeve rings are in good condition so that there would be less drag on the motor and fix the obvious. Then change your breaker out and change the electrical outlet. if your not comfortable with changing these two items DON'T DO IT.
TIP OF THE DAY--To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer. :?) DRRXR
Feb 01, 2009 | Dryers
I want to change the way my doors open on the washer and dryer
washer door can't be reversed on matching dryer best bet buy longer hoses for washer and longer vent and cord for dryer and reverse their locations
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
75 people viewed this question
Top Dryers Experts
