Question about RCA M4208 MP3 Player
NO Power same isue plus...tryed to update the opal,screen backlight comes on but no graphics... given as x-mas gift so no i have no recipt what to do what to do
  • 35 Answers
Try to reflash using these instructions:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2200
Posted on Oct 29, 2009
Brightness doesn't works
have you updated the Graphics Adapter recently? Boot to safe mode, is it the same? Have you tried the Power Options? Open the Control Panel, you didn't post the Make, Model of Laptop or the OS you are using, select Power Options, set to High Performance, select Change Plan/Power settings, set Sleep and Hibernate to Never, adjust brightness to 100%, of course on battery it will dim to save Battery Power. Is the Graphics Adapter NVidia?
Apr 17, 2013 | Computers & Internet
WINDOWS TRIES TO LOAD , THEN SCREEN GOES BLANK.
Try booting to safe Mode (f8), see if you get a normal screen that does not shut off. If you do, then suspect a graphics driver update (usually caused by windows update) that is incompatible with your laptop. Solution is to uninstall the graphics driver and re-install one from the the dell support / downloads website for the OS that you are using.
If it will not boot even in safe mode, try connecting it to an external monitor, if it boots ok on there, you can eliminate graphics chip problems and look at the possibility that it may be the inverter failing or the backlight in the screen.
To give rough indication, if the screen image can be seen in a dark room albeit very faintly, it is the backlight that is the problem, if there is no image at all, suspect the inverter, both are located behind the screen bezel.
If the screen refuses to boot into life on an external monitor, you have a problem with the graphics chip on the motherboard
Jul 27, 2011 | Dell Inspiron 6000 Notebook
The power is on, however the screen is so dark I can not see anything on it. My laptop is brand new. I received for Christmas 2010 as a gift. Do I need to buy a whole new screen?
Do you have a gift reciept?
Do you who gave it to you?
ask for the recipt and return it for exchange or refund.
It's brand new, it's supposed to work well when new. It has some kind of warrenty.
Why on earth would you consider spending money to repair it?
Jan 14, 2011 | Toshiba Helios L675DS7015 Laptop
It's on but nothing is happinging
Well for starters, it doesn't hurt to keep all of your receipts in an envelope, especially for warranty purposes. I have one of these, and because they cost so much money, I couldn't just leave the receipt lying around.....No-one will take something back these days with-out proof of purchase, so you might want to start keeping your receipts somewhere handy.....I hope this answers your question :)
Dec 25, 2009 | Homedics SBM 300H Therapist Select Shiatsu...
RCA Opal M4204-A is stuck initalizing.
Hey all you opal owners..had mine since x-mas and believe it or not even with the glitches it has i love it plus i have the 8 gb one ..anyway had the same problem wouldnt get past initalizing screen..could not re set it either so what i did was...left it on until the battery went down once battery died i turned it back on you will get that low battery screen shutting down and not the intializing screen so right before it did actually shut down i plug in the usb chord and what do you know it recognozes it and then i just upgraded firm ware thats where the problem is you have to upgrade ever since i have done that its been fine..also when playing songs dont skip song to song so fast or it will lock it up
Jul 17, 2008 | RCA OPAL M4001 MP3 Player
Its actually an rca opal M4008
myspacepepe this just worked for me. Try downloading the firmware here:
http://www.fixya.com/support/t322643-rca_opal_m4008a
Then read this solution another user posted. Hopefully this helps you. I had the same issue.
I had this problem. Backing up data wasn't a concern though, as I hadn't anything on the OPAL yet.
First I let the OPAL charge up for 3 hours. Then I made sure it was powered off. I had previously downloaded onto a PC the firmware update for the M4004 which also works on the M4008 and other OPAL's. I plugged the OPAL into the PC, and booted up the PC. After installing the firmware package in the PC, you get an install screen for the new firmware with a format option for the OPAL. I selected that option, but the "start" button was greyed out as the PC still couldn;t see the OPAL. I pressed the reset (paperclip in the back of the OPAL) for about 15 seconds, than held down the "Play" button and waited. Eventually the software recognized the OPAL, and started to format it.
If you get a dialogue to restart the PC, press NO! You have to read the instructions that come with the install. Eventually I reformatted the drive, and installed new firmware.
BTW, there was no picture folder after I did this, so I just created a new folder named picture and it worked fine for the thumbnail pics I threw in there. Also when I use a MAC with the OPAL, I power the MAC up with the OPAL off but attached. After drag and dropping files into the OPAL, I power down the MAC. After power down the OPAL will after a pause give the "building databases please wait" messages, then when done go to the start menu. It is difficult on a MAC to eject the OPAL, it just reappears on the desktop so shutting down is the only safe way to administer the device. But to update firmware, which is easily corrupted BTW if you unplug the thing at the wrong time, you HAVE to do it on a PC operating system. Might work on an Intel MAC with a PC OS though.
Hope this helps.
Jun 03, 2008 | RCA OPAL M4001 MP3 Player
Opal M4002 blue 1 gb inop
Get a clean verison of the software from RCA's website
Apr 19, 2008 | RCA OPAL M4001 MP3 Player
RCA OPAL M4002A Video Problem
You need the specific video converter software from RCA that comes on the CD included with the Opal.  If you don't have that, post here and I'll try to upload the image somewhere as an .iso file.  This is necessary to get the video into the final format the Opal can use.  As far as I know, other video convertors won't format the file properly.
Dec 30, 2007 | RCA OPAL M4001 MP3 Player
RCA Opal M4008
This is the BEST solution. I just had the same problem and ran across this solution and it actually worked. If you are experiencing this problem, this is the only fix I found and I have tried several. Solution #2 posted on Dec 30, 2007 4%20stars_w.png
Billy_K
Rank:nonexpert_s.gif Apprentice
Rating: 95%, 9 votes
Hope this helps.
Dec 28, 2007 | Audio Players & Recorders
RCA M4208  MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
