Question about Dryers
The large hose for our Kenmore 80 series dryer has been disconnected from the dryer and from the wall. What is the best way to reconnect in a tight space?
  • 74 Answers
Buy a flexible hose from walmart or from home depot/lowes
Posted on Sep 05, 2009
Kenmore 80 series dryer banging
Yes you need to replace the tumbler guiding wheels .should do that soon so you don't ruin the motor and belt
May 03, 2014 | Dryers
Kenmore 80 Series dryer's drum is making a thump
I would check all the screw's to make certain they are tight. That was my problem when mine was making noise. Look on the interior of the drum.
Jan 01, 2012 | Kenmore Dryers
If you set the dryer ( kenmore 80 series ) for 50min. it shuts off with about 20 min. left.
disconnect vent hose run dryer, sounds like the vent hose has a restriction
Jan 14, 2011 | Kenmore Dryers
80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
Dec 13, 2009 | Kenmore Dryers
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Not drying clothes - have heat and tumble but probably not air Kenmore 80 series dryer.
Your vent is clogged. Remove hose from back of dryer and wall. vacuum out back of dryer, dryer hose an vent pipe in wall, if it goes out at roof you will need to clean out. Moisture from dryer is getting caught in excess lint trapped in vent causing dryer not to dry.
Sep 20, 2009 | Dryers
What do you do if the silver coil behind the dryer comes disconnected
I'm assuming you're referring to the exhaust hose. If it's an electric dryer, just unplug it and pull the dryer away from the wall and reattach the exhaust hose using the the hose clamp. Make sure it's good and tight before you place it back into position. Plug it in and you're good to go.
If it's a gas dryer, you need to be much more careful. I'd recommend having a qualified tech or handyman do this. You don't want a gas leak. They will know the proper steps involved in disconnecting and reconnecting the gas line so the exhaust hose can be reattached.
Jul 12, 2009 | Whirlpool Dryers
Kenmore Electric Dryer Can't replace heating unit
I removed the deflector and duct from outside the house, disconnected the hose, attached the hose to the dryer, passed the hose through the wall as the dryer went back in, then reattached the hose to the duct/deflector and reinstalled the duct/deflector
Feb 09, 2009 | Kenmore 659 Electric Dryer
Sporatically slow cold water fill (Kenmore Series 80)
Could be you have trapped the hose at the rear of the m/c.
If this is not the case, then I suspect you will need a new cold inlet valve fitting..
Please leave feedback.
Ta.
Dec 09, 2008 | Washing Machines
Kenmore heavy Duty 80 series dryer
exuast needs to be clean and stright out and tight when you heat up that white dryer hose it expands and is most likely blocking air flow if the moisture is not leaving
Nov 22, 2008 | Kenmore 63942 Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
