Question about RCA P52937 52" Rear Projection Television
Rca p52937sg Hello - I have a picture that seems to be getting worse - It startred off that when you first turn on the tv there is a black area at the bottom of picture that slowly goes away as it "warms up"- then a black bar at the top and bottom that seem to get larger over time - again after a few minutes they go away as the picture slowly fills the screen - now when you press the power button the screen is completely black for a momoent - then the picture appears - distorted with the black bars top and bottom - they go away after a few moments and the tv works fine - any suggestions?
    Novelist:
    Champion:
  • 232 Answers
Hi, your vertical section is beginning to fail, from your description you have a few electrolytic capacitors that are beginning to go bad, the correct term is they are "leaky", the set can be fixed easily by a tech, not so easy for a layperson because you don`t have the service manual or a capacitor analyzer. NOT an expensive fix, tech will have to remove board, unsolder some caps, check them and replace the bad ones, do a little touch up solder work and set is good as new, any questions? feel free to ask away, if not Happy Holidays, BMW Rider
Posted on Dec 08, 2007
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Mar 22, 2011 | RCA P52937 52" Rear Projection Television
the part is called the convergence ic. replace those ics.
Mar 22, 2011 | RCA 32F531T 32" TV
Hi i have a RCA P52937SG with the bowing of the screen
The problem may still be on the power supply board (one of the supplies may be missing and) when you unplug the supply both supplies go missing check the supply voltages and repost
Oct 14, 2009 | RCA P52937 52" Rear Projection Television
Tv turns itself off
hello. it sound's like you have a picture tube that is shorting out from a something arking in side of your set.!!! eather on the (CTR PIN COUSHION).!!! OR ON THS CHASSIE.!!! THAT WHAT MAKING IT DO THAT.!!! TIME TO GET A NEW SET.!!! HOPE THIS HELP'S YOU.!!! "GOOD LUCK"
Aug 11, 2008 | RCA 20F511T TV
RCA P52937SG 52" TV Made March 2002
youre having deflection problems could be related to the flyback. But this type of repair is better off with an experienced tech that has the proper equipment and knowledge to diagnose this chassis
Apr 06, 2008 | RCA P52937 52" Rear Projection Television
RCA P52937SG Convergence
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
52" RCA Rear Projection P52937SG Color Dots?
There could be an obstruction in the way of the three picture tubes on the inside. This tv has a chassis that comes out from the back all in a chip core frame with handles. Takes a quarter inch nut driver to remove and you should look to see if the speaker wires or the keyboard wires are obstructing the picture tubes. Other something I think of is a broken reflector and when you get the chassis out you can look up inside behind the screen to check for this and for any other obstructions.
Jan 05, 2008 | RCA P52937 52" Rear Projection Television
Rca p52937sg
Try unpluging it for 15 min.and try it ,if it don't work it might have a leak in your button,it is a simple and cheap repair.I suggest to call your local repair shop.
Dec 23, 2007 | RCA P52937 52" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
210 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
