Question about PANDIGITAL PhotoLink PANSCN06
Pandigital mini photo scanner pictures have white lines on them
I have a pandigital mini photo scanner and all the pictures scan with white lines I have cleaned the scanner and calibrated it multiple times yet the lines continue to show up and they are not consistent different numbers on different pictures and different locations
Have a pandigital scanner that worked great for about 500 pics then lines stared to show up, tried cleaning and calibrating but did not help, decided to take apart and found that the glass on the surface of the scan part was dirty, cleaned the glass and put back together works perfect, took about 10 minutes to fix
Posted on Jul 13, 2010
All the pictures I scan with my pandigital portable photo scanner has lines on it, I have cleaned with the swab and recalibrated and still lines
Posted on Mar 21, 2011
Want to purchase some photo sheets
This is a scanner not a printer. You put photographs or negatives into it and it saves then to SD card or USB.
Pandigital Photolink One Touch PANSCN05 4 Inch x6 Inches Photo and Slide...
Jan 18, 2016 | PANDIGITAL PANSCN05 Photo Scanner with...
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
When I scan a picture, there are 2 lines down the middle of the them.
Clean your scanner and check the connection between your scanner and computer. Try a different cable if needed.
Mar 12, 2011 | PANDIGITAL Office Equipment & Supplies
Scanning photo's on Pandigital Photolink - One Touch Scanner. Scanner is only scanning approximately 1/2 inch of photo
check the set up procedures of the scanner and select the proper size of paper. it sounds like the setting is wrong
Feb 19, 2011 | Office Equipment & Supplies
When I scan a photo, my Brookstone IConvert photo scanner has white lines all over the pictures.
The reason it has white lines is because the glass is dirty in the inside. If it has one speck of anything inside the scanner it turns into a line because it stays in that one place as the picture slides over it. So that line is actually a dot that is covering the picture throughout the scan. The solutions don't work. I don't suggest taking yours apart. I took mine apart and cleaned the glass. The pictures scanned fine and then the lines show up again. The real solution is to get your money back if you can. It will do this over and over. It's a design flaw in the scanner. The picture is actually squeezed as it it scanned. As pictures are squeezed against the glass... residue builds no matter how clean your pictures are.
Jul 30, 2010 | Office Equipment & Supplies
How to get my scanner to scan only the photograph
Most software has a preview button first click this.
Then you can see a dotted line rectangle around the area to be scanned.
You can move this rectangle by dragging the edges using the mouse, (hold click and drag)
Then click the scan button
Feb 22, 2009 | Brother MFC-440CN InkJet Printer
The scanner copies three photos as one
Assuming you're using the Epson Scan software, select Home or Professional mode and click Preview. When the preview image appears, draw a marquee around each of the three photos. (Note that as you draw each marquee the number beneath the little image of a marquee - the white square with the dotted line around it - increases.) After drawing your marquees, click the All button, then click Scan. The scanner should make three separate passes in succession, producing three separate images.
Nov 24, 2008 | Epson Perfection V200 Flatbed Scanner
PANDIGITAL PhotoLink PANSCN06 Logo
2,567 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
David Payne
David Payne
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
