I have a Panasonic receiver that is attached to a set of Sony surround speakers. The subwoofer has cut out for years, and the only way I can seem to fix it is by unplugging the audio input from the subwoofer, tapping it on the input jack, and re-inserting it. It almost needs to get rid of static or something. I`ve recently purchased a new subwoofer (Precision Acoustics) - same problem. Cuts out after a day or so.
-   I have the same problem, except it will only work for about 5 minutes or so. I think the cable that sony provides is very cheap and can be faulty. I don't think that it's a problem with the receiver because it's consistently putting out the sound, it's just the metal contacts between the cable and the sub that's causing the cutting out. It could be the reverberations that vibrate the cable out of contact. I will try to get a higher quality audio cable which will fit more snug on the sub.-   Guest
Apr 08, 2008
-   it was playing music, when it has just cut out but it still has power but wont play music through speakers or sub woofer don't know what to do, any suggestions-   jon147
I need to buy a replacement woofer for my home stereo speakers - It is a 15" woofer for a...
(More)
I need to buy a replacement woofer for my home stereo speakers - It is a 15" woofer for a Cerwin Vega floor speaker about 15 years old.
Need Logitech Z560 schematic. Unit has one weak channel. Speakers not the problem (swapped out and...
(More)
Need Logitech Z560 schematic. Unit has one weak channel. Speakers not the problem (swapped out and problem still exists). Might be cold solder or blown transistor. Would like to see schematic to troubleshoot wiring and connections first.
I can't figure out how to make the speaker go "auto on" when I start my audio source. Do...
(More)
I can't figure out how to make the speaker go "auto on" when I start my audio source. Do i have to use the on/off button on the speaker each time to turn it on?
sharper image wireless speakers, model CT 413, were working fine. today, the blue transmitter light...
(More)
sharper image wireless speakers, model CT 413, were working fine. today, the blue transmitter light isn't on and nothing can seem to make it transmit. suggestions?
