Question about Sony Picture Station DPP-FP70 4x6 Photo Printer
My printer is telling me to change my printer settings to P but i don't know how
HELP I DON'T KNOW HOW TO SET THE TIME. All the
In my experience the letters rise counter-clockwise from the 4 o'clock position.
so, A would be at 4. B at 2. C at 10 and d at 7. Usually the A is a mode selector and B, C and D control the hands and day/date (if you have them) try press B to control day/date and C for changing time forward and D for changing time backwards - whichever is the shortest way.
If you have a 12/24 mode, make sure you are in the right zone is matched with the time and am/pm setting.
Jun 23, 2013 | Watches
I am using a Bizhub C550. I want to print an Illustrator file without maing it a PDF. Once, I was lucky to print 8.5 X 11 file using the Bypass tray. I like rinting through Illustrator ai instead of I
The easiet way is to open all trays and load the bypass and tell the machine you loading 8.5 x 11 on bypass.
You can also set it on any tray within the menu of the copier under paper > then select tray > then change paper tray settings. Usually it is set to auto. but you can change bypass to what ever size you want with respect to the spec of the machine.
Jul 12, 2017 | Konica Minolta Bizhub C550 Color...
Getting error 50.90 fuser error, how do I change the fuse?
I checked 5 different printers and couldn't find a 50.90 error code. Since you keep the printer model a secret I haven't got the foggiest idea as to what the error code means, except that it is a fuser error of some kind. And getting back to your question, If I don't know what kind of printer you have I can't tell you how to change the fuse(r).
Sep 01, 2011 | Office Equipment & Supplies
Describe how to change printer to print only black from my computer. I am out of color ink and don't know how to change the settings from my computer.
Unfortunately, you need both ink cartridges to print with this printer.
you can print grayscale (black/white) by:
This for XP:
Start
Settings
Printers and faxes
Right click the printer icon an select printer preferences
Click the color tab and select grayscale
Windows 7:
Start
Devices and Printers
Select printer preferences
Select features tab
Scroll down and add a dot to grayscale
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 18, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have recent6ly had to have a new router and since then the Lexmark X6570 printer we have won't work,I have concluded that the ip address needs changing to the current one but don't know how to do...
Try to reset the wireless network adapter of the printer. On the printer operator panel:
- Press Settings to display Settings
- Press pattlnk_5182007_1524-left_new.jpg to display Settings
- Press pattlnk_5152007_204-checkmark_alone.jpg to display Network Setup
- Press pattlnk_5182007_1529-right_arrow.jpg to display Network Setup
- Press pattlnk_5152007_204-checkmark_alone.jpg to display Wireless Setup
- Press pattlnk_5182007_1529-right_arrow.jpg twice to display Wireless Setup
- Press pattlnk_5152007_204-checkmark_alone.jpg to display the scrolling message This will reset all wireless network adapter settings. Are you sure?.
- Press pattlnk_5182007_1524-left_new.jpg or pattlnk_5182007_1529-right_arrow.jpg to change the value from No to Yes, and press pattlnk_5152007_204-checkmark_alone.jpg.
The WiFi light on the printer will momentarily turn off. When it lights up solid orange, launch the Lexmark Wireless Setup Utility on your computer by inserting your installation cd or executing the Lexmark X6570 driver. Follow the instructions on your computer screen.
May 05, 2011 | Lexmark X6570 InkJet Printer
Print is compressed on the page. Need to stretch
Compressed print is either a font selection issue or a call for a "SI" (Shift In printer control code)
I suspect the problem can be fixed by going into the printer menu and printing out the printer settings.
Look at the default font and see if it is set to 17,1 or 15.X cpi spacing. If it is then that's the problem.
Change the font to a 10 or 12 cpi spacing (Character per inch).
If the setting is fine, then send me a "Print to File" and I can tell yoi if the software is controling the printer. My address is don.farr@verizon.net
Also, check the application you are using to generate the data file. Make sure you have the correct "Point" size selected for the font.
Don
Jan 20, 2010 | OKI Pacemark 3410 Matrix Printer
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
How do you change the time on the bizhub 7222?
Enter in the user tools and setting the value.If don`t work tell me for more information.
Oct 01, 2009 | Konica Minolta Office Equipment & Supplies
Contact
The following link will tell you how to connect a serial cable & set the address: http://205.200.75.226/support/printer/emulex.html
Aug 02, 2007 | Emulex NETQue Print Server
Sony Picture Station DPP-FP70 4x6 Photo Printer Logo
127 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
