Question about Garden
What is the narrow plastic tube for on our powermate 2700 psi
There is a narrow plastic tube that came with our Powermate 2700 PSI powerwasher. I don't know where or how to secure it and what it's purpose is. can you help?
  • 3 Answers
It could be a tube to **** liquid detergents or cleaners into the water stream. They usually connect to the pump next to where the high pressure hose connects.
Good Luck.
Posted on Sep 05, 2009
Need the manual
A model number would have been helpful; however this may be your manual:
http://www.powermate.com/pdfs/2007/11/10/manual_pw0501400.pdf
If the above is not your manual, check your unit for a model number and then review or search the list here:
http://www.powermate.com/productmanuals.php?cat_id=6
Jun 28, 2011 | Coleman Powermate DuraBuilt 1400 PSI...
Compressor pressure only to 60 lb psi and no more
not sure but it sounds like the piston ring is worn out or you might have a bad valve.
p.s. its not your typical valve like in a car.
is it a wet compressor, check the oil.
Feb 21, 2010 | Coleman Powermate 27 Gallon Air Compressor
No water coming out from powerwasher. Motor is running
check the filter at the inlet water pipe connection, a long nosed pliers may help to remove.
Aug 16, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
The pressure reads 40 psi on both guages on this
with it running check regulator knob .it pulls up turn right pressure should go up.if not regulator bad
Jun 20, 2009 | Coleman Powermate 11 Gallon Air Compressor
Lance
Here is a link where you can look up your exact model and replacement parts from coleman...
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts
Looks like your model may be out of production though so here's a generic kit that will 99% work with your washer...
http://www.silverbin.com/FAIP-PowerWasher-Universal-Pressure-Washer-Gutter/A/B000EEQ9KM.htm
Hope that helps...
Feb 09, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Need new gun and connection to gun
The DuraBuilt and Coleman pressure washers have a gun that tends to leak through the plastic clyinder wall that holds the plunger that moves with the trigger. You won't see the holes, but if you remove the upper half of the housing, hold the plastic tubes in place with one hand and turn on the water, not the motor, you will see water shooting through the wall.
Amazon sells an exact replacement gun and hose. FAIP PowerWasher Replacement Gun and Hose #80012. Mine does not leak at all and was $29 shipped.
Dec 14, 2008 | Coleman Powermate DuraBuilt 1400 PSI...
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
