Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice works, water doesn't kenmore side by side refridgerator
Kenmore side by side, ice but no water
  • 6,784 Answers
HI, make sure that the lines are not frozen. This will happen if the unit is set to a temp that isn't manufacture standards. Once you have verified that the lines are not frozen, This will confirm that the inlet valve is malfunctioning. have it replaced asap.
Posted on Sep 05, 2009
  • 42 Answers
SOURCE: kenmore side by side refridgerator w/water and ice in door
If there is a lot of water dripping and I guess there is since you had to turn the water off, you need to replace the dual solenoid valve to cure your problem. You did not post your model number so it is not possible for me to say if you have more than one valve assembly in your refrigerator. If you have 2 separate valve assemblies you will need to disconnect the lines one at a time to locate the correct valve to replace. I hope this helped you.
supertechks
Please don't forget to rate me
Posted on Jan 25, 2008
  • 1314 Answers
SOURCE: Kenmore Side by Side Fridge - Ice maker/water dispenser
we got to chat about this so hold my rating till we are don how is your water hooked up house valve or self pericing saddle valve what kind of pipes do you have when you push the door dispensor do you hear any sound have you checked your filter
Posted on Mar 31, 2008
  • 1073 Answers
SOURCE: Kenmore no water
does the machine have a lock out button on the despenser that you can push to activate the water and ice
Posted on May 11, 2008
tech master
  • 120 Answers
SOURCE: Kenmore refridgerator #25351694102
check for a lock button on dispencer controls
Posted on Oct 14, 2008
ginko
  • 19396 Answers
SOURCE: Ice maker stopped working
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
Is there a water filter in my 7102 kenmore refridgerator
There could be one in the water line that feeds the ice maker.
Apr 03, 2014 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 10673184302
Try to defroust the refrigerator because generaly when there is lot of ice accoumulated in the freezer the fan which throws the air inside the freezer malfunctions some times or you can stop the refrigerator for few hours so that the ice covering out side the freezer or out side the tubes gets melted completly .
Aug 17, 2012 | Kenmore Refrigerators
Why doesnt the water and ice work on my side x side kenmore refridgerator
1st-Make sure you have water entering the unit. 2nd- If you have recently replaced the water filter- make sure it is properly installed. When you press the water dispenser, you should be able to hear the water valve energizing. If all fails, your best resource is to have a Sears tech service the unit specially if Ice-maker continues Not to function. It might be costly but they warranty the work without any stories.
Oct 05, 2010 | Kenmore 57029 Side by Side Refrigerator
I WAS WONDERING ABOUT THE ICE MACHINE,IT ISN'T
check for water then check water valve where hose connects. the see if the is water in ice maker if so then wait for ice, if no water it could be the valve
Jul 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
May 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Aug 05, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore no water
Apr 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not working
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Dec 17, 2007 | Kenmore 21.7 cu. ft. Side-by-Side...
Please help
Are you installing a ice maker kit? If the ice maker is already installed all you have to do is connect it to the potable water supply in the back of the refrigerator and lower the bail arm to put it into operation.
Jul 15, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
80 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
