Question about ViewSonic VX2235wm LCD Monitor
My viewsonic vx2235 has a blue light on but no picture at all. Can i still use this monitor? I really dont want to buy another one so i am hope that i can just replace a part cheaply. Theres power but no picture and i have tried it on severial computers.
  • 58 Answers
Assuming your cable is good & your PC (video card) is properly functioning & everything is plugged in correctly,;
If the screen flickers a bit when you start it, then the problem may be in the power circuits. Open the back & look for burned components on the circuit board. (capacitors, fuses, resistors, transistors, whatever.)
If it does not flicker then the bulb is likely burned out.
ALSO: you should read this guy's experience. ----> http://www.avsforum.com/avs-vb/showthread.php?t=1136249
Posted on Sep 05, 2009
Hello,I am currently using a Viewsonic VX2235 monitor. When I turn on the PC the monitor stays black and it takes turning the monitor on and off several times to get it to work. Would greatly appreciate...
The problem you are having is caused by a power supply board that is starting to fail. Parts called capacitors start to fail and the power supply does not start up as it should and requires power cycling to get it going. Most VX2235 units use the DAC-19M010 power board. Here is a link that shows how to repair the board by replacing the bad capacitors.
http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2216w-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 18, 2011 | ViewSonic VX2235wm LCD Monitor
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
No display
Look for bad caps as shown in the VX2235 album.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed Viewsonic Monitors pictures: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 28, 2010 | ViewSonic VX2235wm LCD Monitor
My monitor viewsonic vx2235 wm model VS11349 has not picture. Power but no picture. Can you help me figure out what's wrong? Thanks
Hi the problem from the power board . If you are comfortable with soldering all you have to do is open up your monitor ,remove cables connected to power board. Make a sketch of what it looks like noting the location of the capacitors and thier rating . All you have to do is replace them with ones of the same rating and couple them back. The ratings would look like this 10uf/25v it's better to find exact match or if you have 220uf/25v ,you can replace with 220uf/35v.
Jul 28, 2010 | ViewSonic VX2235wm LCD Monitor
Hey I have a viewsonic VX2245WM and my problem is that when I turn my computer on the monitor light goes red-ish like a red light that is starting to fade away and the screen is completely black like its...
Almost the same chassis as VX2235.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 19, 2010 | ViewSonic VX2245WM LCD Monitor
I have a viewsonic LCD VX2235 and it just went black. It switches from the green light to amber light with no picture but you can see a faint flicker in the background. Please help
Look for bad caps with bulging tops as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
They should be replaced as a set (6 black cases, 2 brown cases). Use PANASONIC FM or F series from Digikey.
Apr 20, 2010 | ViewSonic VX2235WM Monitor
I have a ViewSonic VX2235. No picture at all
sounds like a burnt or a cold solder around the TRANSFORMER section of the power supply , I suggets if your handy w/ tools to open the monitor and inspect the PC BOARD for any burnt or cold solder THAT not making the connection , hope it helps AJ
Nov 09, 2009 | ViewSonic VX2235WM Monitor
Black screen
Don't let the computer turn the monitor off. Go into control panel and click on power option. don't let the computer turn anything off and disable hibernation if on. go to screen saver and have it come on in about 30 mins.
May 27, 2009 | ViewSonic VX2235wm LCD Monitor
I just bought a viewsonic vx2240w. When I change the resolution to 1680x1050 the page becomes too wide for the screen. I have to scroll left and write just to see it.
This sounds like an issue with the windows driver for your video card. I have to load the viewsonic driver for my monitor first and make sure the device monitor is showing the vx2235 and not default monitor. Then make sure your video board will support the 10 x 16 format and check for any settings about horizontal scrolling. If you are running an ATI card, get the latest version of the Catalyst drivers from their web site. Hope this helps.
Feb 02, 2009 | ViewSonic VX2235WM Monitor
ViewSonic VX2235wm LCD Monitor Logo
1,965 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
