Question about Poulan Pro 22" Self Propelled High Wheel Mower
Poulan Pro 22" does not mulch!
I bought a Poulan Pro 22" self-propelled mower and it does not mulch right. It leaves my lawn looking like a hay field. What do I need to do?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
When you mulch you can only cut 1/3 of the grass off. If the grass is 3" high you can only cut 1" off.If you are cutting more grass of than you are leaving there is no place to hide the clippings.A general rule is if you notice clippings and clumps beginning to lay set the mower up one notch at a time until the clippings are hardly noticeable.If you like a real low cut then mulching is probably not for you,you will probably want to bag the grass instead.Hope this helps.
Posted on Sep 06, 2009
I just inherited a Poulan Pro Electric 625 Series Self-Propelled Lawn Mower. I used it once...it started quickly but the self-propelled function doesn't seem to work very well. I have had other...
This sounds like a simple belt adjustment. Look in the area where the belt is . Look to see if there is an adjusting screw, or a movable pulley, or just something that will tighten the belt. Lift the mower and look underneath the mower deck. This may be where the adjustment may be. If you can't find the area of adjustment, then you may have to bring in to the repair guy. Either way it's cheaper than a new mower. GOOD LUCK>
Jun 28, 2011 | Poulan Pro 22" Self Propelled High Wheel...
Looking for 22" blade for a Poulan - PO550N22SH - PN 961120080 - where can I buy a lawnmower blade? Can find the number on the internet, but can't find a dealer that sells this product.
Your Poulan Pro mower is made by American Yard Products and the parts will interchange directly with Craftsman 22" mowers. You should be able to find a replacement at your local Sears store. All of these part #s are also 22" AYP blades:
AYP #'s
406713
192682
157101
335256
114886
141114
Rotary #15-6236
Oregon #
95-043
95-042
95-055
95-023
95-021
95-602
The different #'s should all fit. Some of them are bagging style blades (high lift) while others are designed to mulch.
Online sources will include www.searspartsdirect.com and www.amazon.com
Good Luck!
Aug 25, 2010 | Poulan Pro 22" Self Propelled High Wheel...
How to change oil in poulan 22 self-propelled mower
there should be a drain plug under the mower near the shaft that the blade is connected to... good luck
Apr 07, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Where is the oil drain plug for a poulan self propelled 22 inch 625 series mower
remove spark plug wire from plug,tip machine on its side.look under blade for a threaded plug with a square head where bottom of motor protrudes through deck.on most models you can simply tip machine over far enough to allow oil to drain out the dipstick[filler]tube.
Sep 27, 2009 | Poulan Pro " Pro" Self Propelled Mower
I just bought a Poulan Pro lawn mower and after the first use it is leaking oil around the shaft.
if its new take it back tell them you want one that doesnt leak
be sure it is not overfull of oil
if you dont want to take it back replace the crankshaft seal
Jul 05, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
330 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
