Wont drain water
Washing machine Series 80 Kenmore wont drain water after it's RINSE cylce.
  • 6,784 Answers
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Sep 05, 2009
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore 80 series washing machine - won't stop filling with water on rinse cycle - never moves to next cycle - if I stop machine and manually move to spin, the machine does spin and the water drains
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
Use this manual to access these parts and diagnose which is bad.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine Series 80 Kenmore wont drain water after it's RINSE cylce including the motor. It's like the TIMER stopped after the RINSE CYCLE. I think it's the timer.
does it drain after the wash cycle? if it does, then I don't think it's the timer. It uses the same contact there as for the rinse cycle. Do you hear the motor running as if it's trying to drain? If the motor is running, perhaps the pump itself is no good? Just a couple things to check. Hope it helps.
Joe
Sep 05, 2009 | Kenmore Washing Machines
Washes great but wont drain or spin
sounds like a broken lid switch it will usually stop in the rinse cyc and not advance
Aug 27, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore 80 top load series wont rinse top load wont rinse
drain pump is trying to drain. maybe have something in pump
Jun 22, 2009 | Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Trouble shooting kenmore washing machine 80 series.
washer will fill with water that's it, will not operate on any cycle
Jun 22, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
