Question about RTO PasLode 900420 Impulse Framing Nailer
Gun not firing batt charge, new gas, fan goes just not firing
  • 2,176 Answers
Could be a couple things, first are there nails in the magazine, this tool has a stop when low on nails it won't fire, second is the lower probe bent not allowing full push on the cylinder to load gas. Give me the model number and I will find a print or you can go to Paslode.com and type in the model number and get an owners manual that has a trouble shooting guide in it for help. Let me know and if I have helped you with your question would you please rate this response accordingly.
Posted on Sep 06, 2009
  • 3 Answers
I had similar trouble, and believe or not, new gas had no pressure enough to work. To check this, push gas pipe on the bottle ventile, it should spray visible amount of gas. (sorry my bad language).
Posted on Oct 08, 2009
How do I get my finish nail gun to fire?
don't have any of them but sounds jammed from sitting . too dry. anyplace tto put oil for the driver to move?
Aug 23, 2015 | Air Tools & Compressors
I have a paslode model IM250II 16 ga straight finish nailer that I bought used the gun fan and motor runs whin the trigger is pulled but it does not fire when the tip is pressed no pop no puff nothing I...
Fan running when trigger pressed is normal however to make it fire you need to press on the work probe first and the fan should start running, at this point the gas should be injected and pressing the trigger should create the spark to fire the gun, if all works as above but the gun won't fire check the gas, the metering valve on the can should have a yellow ring and when pressing the can nozzle on a hard surface, gas should be released, if not the can either has (a) insufficient gas, (b) the nozzle is not correctly fitted (c) the metering valve is faulty, if the can emits gas the gun will need to be checked for spark and the seals will need checking
Aug 21, 2013 | Tools & Hardware - Others
I have a new im65a pasloade nail gun that has only fired a couple of hundred nails and after standing for about 16 months the gun does not seem to be firing the fan comes on the green light flash the
your gas has expired , look at bottom of canister check the date. buy new gas also make sure cap on gas canister is down all the way till it snapps new gas doesnt come with cap down all the way
Apr 24, 2012 | Senco Air Tools & Compressors
Paslode IM350 90CT Nail Gun gun light green gas full battery charged fan works gun wont fire
Try a different gas cartridge and make sure the top of the cartridge is snapped tightly onto the cartridge body.
Jun 23, 2011 | Air Tools & Compressors
The problem of intermittent firing began some time ago. Now the gun will not fire at all. The gas bottle is full and the battery is fully charged. I disassembled and cleaned the gun. It subsequently fired...
what is the expiration date on the bottom of the fuel cell?? Also what were the condition of the o rings and did you relube with a good quallity oil. What I would do is remove the front assembly to expose the fan only and then insert a battery, pull the trigger and the fan should run for a few seconds, next there is a roller lever towards the top, depress it keeping fingers away from fan and again it should run for a few seconds, next depress and hold the lever and then pull the trigger and you should see it fire, repeat this several times, that will narrow it down to the spark unit/electronic assenbly or the cylinder.
Jan 09, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Pasload cordless finishing gun - still won't fire
barrel and fan cover 'o' rings may be leaking/ need replacing. item no 17 on the parts diagram.
Do you have a spark, you should just be able to hear the spark firing when the gun is applied to the work surface and the trigger pulled, it sounds like a click.if no spark heard it could be the switch on the fan head not working , a bad ignitor , or the spark is not sparking in the correct place, chaffed ignition wires.
is the gas you are using in date, there should be a date stamp on the gas bottle. if its out of date it can give problems.
Jul 19, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Hitachi Framing Gun Not Firing - Bad Battery?
Does the fan run and the light blink ont he nailer? I have one that I just bought. I put in the wrong type of nails and got one stuck. I had to take the front apart to clear it and now the damm thing wont fire. The green light blinks and the gas cartridge is basically full, even the fan does run after I release the push lever, but no fire???
I wonder if yours is the same as mine did fire for a couple nails first just fine then got jammed...
I will try to charge the battery more.... MAybe like yours it needs a strong charge for the spark...
Russ
Sep 28, 2008 | Hitachi NR90GR Cordless Round Head Gas...
RTO PasLode 900420 Impulse Framing Nailer  Logo
658 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
