Question about Kenmore Kitchen Ranges
How do you open the stove lid of a Kenmore 7907138 five burner gas range? I need to clean it.
    President:
  • 1,015 Answers
You need to be careful with sealed burner ranges. If you try to lift the range top you can damage the alluminum gas pipes for the burners under the range top. Check to see if the burner heads lift off. If the burner heads are held on by screws make sure you remove those first. With the heads removed look down into the cooktop thru the hole where the burner sits. Make sure the orfice is not attached to the lid. If they are you may see a screw you can remove. Look for any other screws behind the oven door that may be attached to the lid. Apply light pressure when trying to lift the lid. If you feel any major resistence DO NOT FORCE IT UP. Sears.com also has parts schematics for every range they make and that will visually help with the dis-assembly because you can see how the parts go together. Also MAKE SURE YOU UNPLUG THE APPLIANCE AND TURN OFF THE GAS VALVE BEFORE WORKING ON IT!!!
Posted on Sep 05, 2009
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
How do i open the top of stove to clean its lrg30855st
Turn off the gas. Lift off the burner cap and the burner head from all remove the torx screws under each of the five burner heads then lift off he top. The picture on these two pages of the manual show where the screws are and what the stove looks like with the top off:
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=21#manual
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=22#manual
Oct 05, 2014 | LG LRG30855ST Stainless Steel Gas Range
All five burners worked fine till I cleaned it now three dont work
These burners can be a pain sometimes.... first of all did you let them air dry and shake them to make sure all of the water is out of them ... any water in them will prevent them from working correctly. Secondly, are you sure you seated them correctly on the burner receptical? Third... make sure you have spark from the igniter... there may be water or moisture on them grounding out the spark and preventing the spark to jump to the gas to make a flame.
Good luck and I hope it works.
Aug 26, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
I have a Kenmore Gas range. The major stove top no longer gets really hot and we are having trouble boiling large pots of water. It used to be able to boil a large pot of water easily. I would like to...
This could be a problem with the gas regulator, gas supply pressure or the burners need to be cleaned. Here are the cleaning instructions for the burners. If you are still having problems with the burners I would recommend having the gas pressure & regulator checked.
Jan 16, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
We took apart our kenmore gas stove because a rat had been living in it. We cleaned it up and now can't put it back together! We are looking for an assembly manual. Please help.
How do I open the top of my Kenmore stove to clean under it? I am trying to clean it because some of the burners don't want to light when I turn the knobs.
Jul 19, 2009 | Kenmore Kitchen Ranges
Kenmore Gas Stove gas takes a long time before it will come out
First, I'm not a Kenmore Tech.
* call vendor for service. Gas leaks are hazardous and require a qualified tech to service.
*** The following is for information only.***
* I've always had problems servicing gas stove, heaters, boilers, etc. Lots of unique components that require special tools to service.
* I was surprised to find out that it's better to call on your local Gas Supplier for service. The not only check the supply line but also have a very good working experience with all types of gas fired equipment.
* Slow pilot lighting or burner fire usually means a clogged gas vent or valve. If other burners are working fine, then it's just that particular burner.
* If all burners have the same symptom then it could be a number of things.
* Check gas mains for pressure and flow (you need a gas meter for this but if you have another stove on the same line then it's probable that the mains are okay. Unless the connector or shutoff valve is not working properly (partial open).
* Check gas hose to stove for kinks. Replace if bent (re bending will crack a metal hose.)
* Check the gas regulator (again, need a gas meter)
* Check the feed and branches for gas. If pilot lights are not on then there is a good indication that your not getting gas to that section. (or the pilot is clogged) Clean, clear, or replace pipes/parts.
* Check valve on each burner. This is the most used item on the stove. Expect it to wear out. Replace as needed.
* Final, Be safe; Call your Gas company or MFR tech for service.
Aloha, ukeboy57
PS check youtube for: "Sears Kenmore Gas Oven Problems"
Feb 21, 2018 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore gas range
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
Nov 06, 2008 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Dec 06, 2007 | Kitchen Ranges
Kitchen Ranges Logo
400 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
