Question about Sony STR-DE845 Receiver
Sony STR DE845: rear speakers not working, three fronts are OK.
I moved and am reconnecting the unit. The Rear speakers are not working in any mode. I reset unit to factory specs per the Sony manual instructions... to no avail. I do not have anything connected to the surround inputs. Although I have the Sat/TV, DVD and Video 1 inputs connected. Prior to moving, I discovered the right rear channel not functioning (I noticed the right rear speaker problem after a Direct TV installation tech switched out my Direct TVR. I assumed that it was a loose wire) now it seems neither of the two rear channels are working.I disconnected and reconnected the speaker wires. I ran the onboard "tone" check and the three front speakers function and supply the 'white noise' indication. The rears are silent when the display indicated that they were being tested. Are the rear speakers fuse protected?
Anyone with an idea of what might be going on??
    Brigadier General:
  • 8,546 Answers
The rear amp is malfunctioning (duh). Take it to a tech for a real diagnosis.
Posted on Jan 21, 2011
Sony str-de945 s.1 rear speakers not working
rear speakers may only work once you have a 5.1 or DTS signal source connected
Apr 20, 2014 | Sony STR-DE945 Receiver
STR-DE845 Stuck in Demo mode, tried the power and ...
To get the STR-DE845 ( or STR-DE945 ) out of DEMO MODE - Turn unit on and HOLD POWER BUTTON FOR A FEW SECONDS ...Turn unit off and when you turn it on again it should be reset ...It worked for me.
( Note : You may need to do this procedure before it goes into its actual demonstration of features ... Press and hold the power button immediately when it initially starts scrolling it's DEMONSTRATION MODE message . )
May 12, 2010 | Audio Players & Recorders
I have a Sony STR-DE845 receiver. The rear
Something is heating up to a point that it fails in the rear amplifier section. take it to a tech.
Jan 01, 2010 | Sony STR-DE845 Receiver
Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Sep 15, 2009 | Sony STR-DE845 Receiver
My reciever turns itself off
You most likey have a wire short on your center or rear surround speakers. The wire short will be between the + and - points of the speaker wire.
To find the problem speaker, disconnect one of the 3 speakers at a time from the back of the sony and see if the problem goes away. Once you identified the offending speaker, check both the sony side and speaker side for the short. The small wire strands are hard to see and it only takes one to trip the protection mode, so look carefully.
Mar 07, 2009 | Sony STR-DE845 Receiver
I have a Sony STR-DE635. It has a switch on the front for speakers A, B, and A+B. Normal. When I am on speaker A only, it works fine. B does not work. A+B works, but only through the A speakers. Now,...
Check for bad solder connections on the speaker switch or where the speaker switch board connects to another board. Not an uncommon problem with some Sony receivers.
Feb 25, 2009 | Sony STR-DE845 Receiver
Sony STR de845, 5.1 Surround does not work. 3.2 is indicated o
3.2 IS the "5.1" mode for this receiver. 3.2 is indicating that you have 3 front channels and 2 rear channels. The ".1" is applied to all the speakers (LFE). If you read the manual on page 37, you'll see that "3.2" is displayed with either "Dolby Digital 3.2" or "DTS 3.2". The little icons of the speakers in the display window will show you which channels are active. The bottom line is as long as you see the blue light, it's decoding multi-channel discreet surround sound (at least 5.1).
Nov 22, 2008 | Sony STR-DE845 Receiver
Sony STR-DE845 Receiver Logo
674 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
